Beams and Applications Seminar: Transition from 352 MHz Klystrons to Solid state RF Power at the APS
Type Of Event
Seminar
Sponsoring Division
APS
Location
401/A5000
Building Number
401
Room Number
A5000
Speaker
Doug Horan, Accelerator Systems Division – RF Group, Argonne National Laboratory
Host
Joe Calvey
Start Date
06-12-2025
Start Time
3:00 p.m.
Description
Abstract:
An upgrade of the Advanced Photon Source 352MHz rf systems is underway that involves phasing out the existing APS klystron vacuum tube rf power amplifiers and replacing them with state-of-the-art solid state rf amplifier (SSA) technology. Laterally-diffused metal oxide semiconductor (LDMOS) transistors are used to produce approximately 1.25kW of cw rf power per device, followed by a series of rf power structures that combine the module outputs to achieve 160kW cw final output power per system.  This SSA upgrade eliminates the need for high voltage dc power, reduces noise on the rf power, provides built-in power redundancy, and improves system reliability.  The APS solid state rf system topology will be discussed, along with R&D efforts in solid state, implementation plans for the 160kW SSA systems, and a brief review of klystron performance and operating history at APS.
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
