CITIUS: A 17,400 Frames/s X-ray Imaging Detector with a Linear Response of Up to 945 Mcps/pixel
Type Of Event
Presentation
Sponsoring Division
XSD
Location
Virtual
Speaker
Takaki Hatsui RIKEN SPring-8 Center
Host
Nino Miceli
Start Date
09-12-2023
Start Time
3:00 p.m.
Description
Abstract:
We report our recent progress in the CITIUS (Charge Integration Type Imaging Unit with high-Speed extended-dynamic-range) detector. It has been developed to overcome the count rate limitation of the current state-of-the-art photon counting detector by introducing novel integrating-type pixels with a size of 72.6 micrometers and a high frame rate of 17.4 kfps [1]. Recently we succeeded in experimentally demonstrating its detecting capability of 945 Mcps/pixel (18 Tcps/cm2) at 10 keV while keeping its single photon sensitivity. In this talk, we report our development status including the performance evaluation and the on-the-fly data processing with FPGAs. A feasibility study of Bragg CDI was carried out at ESRF last year [2]. At SPring-8, applications of these detector systems to XPCS, ptychography [3], SAXS & WAXS, X-ray beam monitors by using spectro-imaging capability, and fluorescence yield XAFS by using large-area high-count-rate energy resolving detection are in progress. The status of these applications is also reported.
 Table I Specifications of CITIUS variant for Synchrotron radiation experiments
Parameters
Value
Sensor
Thickness
650 µm
Pixel Size
72.6 µm
Pixel Number
0.28 Mpixel/sensor
Noise
0.027 phs.@8 keV (60 e-)
Peak Signal
1,800 phs. @ 12 keV
Frame Rate
17.4 kHz
Sat. Count Rate @12 keV
30 or 600 Mcps (*)
Largest System
Pixel Number
20.2 Mpixel
Image Area
325 x 363 mm
(*) 30 Mcps with standard operation. 600 Mcps in an extended mode
 References
  1. SPring-8 II Conceptual Design Report, RIKEN SPring-8 Center, 2014.
  2. Michael Grimes, J. Appl. Cryst. (2023). 56, 1032. (https://doi.org/10.1107/S1600576723004314)
  3. Y. Takahashi, et.al., J. Synchrotron Rad. in press. (https://doi.org/10.1107/S1600577523004897)
Background material: https://anl.box.com/s/satlx5xygsr32fidfpo5s022am3ghoul
Join ZoomGov Meeting
https://argonne.zoomgov.com/j/1617418964?pwd=UlIrRzZXU1lDU29VUG9pOWlxMmU3UT09
Meeting ID: 161 741 8964
Passcode: 846782
One tap mobile
+16692545252,1617418964# US (San Jose)
+16468287666,1617418964# US (New York)
Dial by your location
• +1 669 254 5252 US (San Jose)
• +1 646 828 7666 US (New York)
• +1 646 964 1167 US (US Spanish Line)
• +1 551 285 1373 US (New Jersey)
• +1 669 216 1590 US (San Jose)
• +1 415 449 4000 US (US Spanish Line)
Find your local number: https://argonne.zoomgov.com/u/adGFZBJMvm
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
