Dark Field X-ray Microscopy: A New Way of 4D Mapping of Strain and Orientation of Embedded Crystalline Structures
Type Of Event
Presentation
Sponsoring Division
XSD
Location
Virtual
Speaker
Can Yildirim, European Synchrotron Radiation Facility
Host
Jon Almer
Start Date
05-30-2023
Start Time
09:00 a.m.
Description
Abstract:
Macroscopic physical and mechanical properties of many technological materials are determined by their hierarchically-organized structures such as grains, domains, and defects. These structures span over length scales ranging from nanometers to millimeters. Understanding the interplay between these length scales is of critical importance not only for improving material properties but also for validation of multi-scale models. Here, we present Dark Field X-ray Microscopy (DFXM), a diffraction-based synchrotron method for probing 3D nanostructures with their associated strain and orientation in bulk materials. Analogous to dark-field electron microscopy, DFXM comprises an objective lens to magnify diffracting features from millimeter-sized samples [1-2]. The resulting spatial and angular resolutions are on the order of 100 nm and 0.001°, respectively. DFXM is a full field imaging technique. This allows for recording 3D strain and orientation maps of the entire heterogeneity in a given grain within seconds to minutes, thus capturing time-resolved phenomena. The microscope can be coupled with coarser grain mapping methods such as 3DXRD and Diffraction Contrast Tomography (DCT) without having to dismount the sample. Here, we demonstrate the microstructure-property relationships in metal alloys such as steel, aluminum, and nickel along with functional oxides and semiconductor materials using DFXM [3-6].
References
[1] Kutsal et al., IOP Conf. Series: Materials Science and Engineering, 2019, 580, 012007
[2] Simons et al., 5) Nature Communications, 2015, 6, 6098.
[3] Mavrikakis et al., Acta Materialia. 2019, 174, 92104.
[4] Yildirim et al., Acta Materialia, 2021, 117290.
[5] Yildirim et al., MRS Bulletin, 2020, 45, 277
[6] Yildirim, et al, Scripta Materialia, 2022, 214, 114689
Microsoft Teams Information
Click here to join the meeting
Meeting ID: 225 216 741 051
Passcode: Lca9j4
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
