Optimization of Large Area Metamaterials
Type Of Event
Presentation
Sponsoring Division
XSD
Location
Virtual
Speaker
Maksym Zhelyeznyakov
Host
Arthur Glowacki
Start Date
05-08-2023
Start Time
09:00 a.m.
Description
Abstract:
In recent years, quasi-periodic arrays of dielectric scatterers, also known as meta surfaces, have been shown to manipulate electromagnetic scattering with sub-wavelength spatial resolution. These devices have proven to be incredibly useful for reducing the form factor of conventional optical devices, as well as creating novel optical devices that are not possible to realize with conventional refractive optics. The design of these devices is however non-trivial. Conventional forward design methods are useful for generating only a small subset of possible designs. More complicated designs as well as optimization of existing forward designs requires solving the full-wave Maxwell's equations many times to converge to an optimal device design. This presentation outlines three main advancements in computational electromagnetics for the design of meta surfaces. Firstly, we extend the Generalized Multi-sphere Mie Scattering (GMMT) method to ellipsoidal scatterers. This method solves Maxwell's equations and computes gradients with respect to geometric design parameters of meta surfaces composed of ellipsoidal, dielectric scatterers analytically. We use this method to fully inverse design a meta surface lens, a meta-grating that focuses light at different focal planes for different polarizations and improve the efficiency of a forward designed lens from 25.59% to 32.00%. The second method is a data-driven method that predicts electromagnetic fields from wavelength-scale cylindrical pillars, obtaining a low-dimensional representation of the data via the singular value decomposition. This method fits a differentiable neural-network model of the input geometries and configurations of the meta surface scatterers to the low-dimensional representations of the output field. This framework was used to design a device that produces an annular focal spot for the λ=400nm wavelength, and a focal spot for the λ=633nm wavelength. Finally, we present a data-free machine learning framework for predicting electromagnetic field responses from meta surfaces by using physics informed neural networks. This method predicts full fields from 1D meta-gratings by a neural network that is trained by minimizing the residual norm of the Maxwell operator. We use this technique to design a set of large area (1mm) meta-lenses exhibiting higher efficiency than the ones designed under the local phase approximation. We validate our designs experimentally and see a maximum intensity improvement of up to 53%.
Join Teams Meeting
https://teams.microsoft.com/l/meetup-join/19%3ameeting_NDcwOTk4ZmUtMmMxMy00ZjIzLThjMTQtN2E4ZmZjNmQ0ZDFm%40thread.v2/0?context=%7b%22Tid%22%3a%220cfca185-25f7-49e3-8ae7-704d5326e285%22%2c%22Oid%22%3a%22c1b97440-7149-429c-a337-88f29b15c9b2%22%7d
To report an event that is not listed, please contact webmaster, for additional synchrotron-related conferences, check lightsources.org.
