Abstract:
High-pressure chemistry is known to inspire the creation of unexpected new classes of compounds with exceptional properties. Despite general trends that pressure leads to the formation of dense compounds with highly coordinated elements, sometimes high-pressure synthesis may counterintuitively lead to the formation of porous or even van der Waals (vdW) bonded layered compounds. Since vdW compounds could potentially be used as precursors to 2D materials, the structural diversity of the accessible high-pressure phases may be used for the design of novel single-layer materials.
Here, we employ the laser-heated diamond anvil cell technique for synthesis of a Dirac material BeN4 and pentagonal NiN2. A triclinic phase of beryllium tetranitride tr-BeN4 was synthesized from elements at ∼85 GPa. Upon decompression to ambient conditions, it transforms into a compound with atomic-thick BeN4 layers interconnected via weak van der Waals bonds and consisting of polyacetylene-like nitrogen chains with conjugated π systems and Be atoms in square-planar coordination. Theoretical calculations for a single BeN4 layer show that its electronic lattice is described by a slightly distorted honeycomb structure reminiscent of the graphene lattice and the presence of Dirac points in the electronic band structure at the Fermi level. The BeN4 layer, i.e., beryllonitrene, represents a qualitatively new class of 2D materials that can be built of a metal atom and polymeric nitrogen chains and host anisotropic Dirac fermions.
High-pressure synthesis from elements leads to a novel nickel diazenide NiN2 which possesses atomic-thick layers comprised of Ni2N3 pentagons forming Cairo-type tessellation. The layers of NiN2 are weakly bonded with the calculated exfoliation energy of 0.72 J/m2, which is just slightly larger than that of graphene. The compound crystallizes in the space group of the ideal Cairo tiling (P4/mbm) and possesses significant anisotropy of elastic properties. The single-layer NiN2 is a direct-band-gap semiconductor, while the bulk material is metallic. This indicates the promise of NiN2 to be a precursor of a pentagonal 2D material with a tunable direct band gap.
M. Bykov et al. Realization of an Ideal Cairo Tessellation in Nickel Diazenide NiN2: High-Pressure Route to Pentagonal 2D Materials. ACS Nano 15(8), 13539 (2021)
M. Bykov et al. High-Pressure Synthesis of Dirac Materials: Layered van der Waals Bonded BeN4 Polymorph Physical Review Letters 126, 175501 (2021)
For information about Dr. Maxim Bykov’s research, please check the link: https://agbykov-iac.uni-koeln.de
- M. Bykov et al. Realization of an Ideal Cairo Tessellation in Nickel Diazenide NiN2: HighPressure Route to Pentagonal 2D Materials. ACS Nano 15(8), 13539 (2021)
- M. Bykov et al. High-Pressure Synthesis of Dirac Materials: Layered van der Waals Bonded BeN4 Polymorph Physical Review Letters 126, 175501 (2021)
To Join ZoomGov Meeting: https://argonne.zoomgov.com/j/16140461760?pwd=bThydTZLaVlyaER1U3JrRXRqM2l6QT09
Meeting ID: 161 4046 1760
Passcode: 1760
One tap mobile
+16692545252,,16140461760# US (San Jose)
+16468287666,,16140461760# US (New York)
Or Find your local number: https://argonne.zoomgov.com/u/ad7OPqE86v
