On 07.09.2016 22:07, Kevin Peterson wrote:
> Replacing this:
> $(COMMON_DIR)/snl.bnf: snl.lem
> $(LEMON) o=. -g $< > $@
> with
> $(abspath $(LEMON)) o=. -g $< > $(@F).tmp
> $(MV) $(@F).tmp $@
> allows me to build seq-2.2.3 against base-3.15.4 using both VS2010 and
> VS2015 using a single "make".
Thanks Kevin, seems I did not really understand the explanation of the
problem. I made a patch that sets LEMON = $(abspath
$(INSTALL_HOST_BIN)/lemon$(HOSTEXE)) for the base-3.15 case (for
base-3.14 PATH_FILTER converts the path to backslashes which is the
reason the problem does not appear here). It will go into 2.2.4 (and is
also contained in the latest snapshot).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: OpenPGP digital signature
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Andrew Johnson
Re: VDCT Ralph Lange
motor command in synApp when invoking the drive file l123173
<2016>
Is There A Way to Explicitly Close CA Connections in PyEpics? Weiwei Lu
<2016>
ANJ, 08 Sep 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
