Thanks Andrew.
Replacing this:
$(COMMON_DIR)/snl.bnf: snl.lem
$(LEMON) o=. -g $< > $@
with
$(abspath $(LEMON)) o=. -g $< > $(@F).tmp
$(MV) $(@F).tmp $@
allows me to build seq-2.2.3 against base-3.15.4 using both VS2010 and
VS2015 using a single "make".
Kevin
On 9/7/16 2:53 PM, Andrew Johnson wrote:
> On 09/07/2016 02:46 PM, Kevin Peterson wrote:
>> That change doesn't eliminate the build error:
>> "Installing created executable ../../../bin/windows-x64-static/snc.exe"
>> ../Makefile:59: PATH_FILTER is deprecated; used for
>> ../../../bin/windows-x64-static/lemon.exe
>> ../../../bin/windows-x64-static/lemon.exe o=. -g ../snl.lem > snl.bnf.tmp
>> '..' is not recognized as an internal or external command,
>> operable program or batch file.
>> ../Makefile:59: recipe for target '../O.Common/snl.bnf' failed
>>> $(LEMON) o=. -g $< > $(@F).tmp
>>> $(MV) $(@F).tmp $@
> The problem is that the Windows command shell doesn't like relative
> paths to executables, unless they use backwards slashes. Try replacing
> $(LEMON) with $(abspath $(LEMON)) to see if that helps.
> - Andrew
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Andrew Johnson
RE: Autosave ignores PVs starting with some characters Mooney, Tim M.
Re: github hides accounts Kevin Peterson
<2016>
<2016>
ANJ, 08 Sep 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
