That change doesn't eliminate the build error:
"Installing created executable ../../../bin/windows-x64-static/snc.exe"
../Makefile:59: PATH_FILTER is deprecated; used for
../../../bin/windows-x64-static/lemon.exe
../../../bin/windows-x64-static/lemon.exe o=. -g ../snl.lem > snl.bnf.tmp
'..' is not recognized as an internal or external command,
operable program or batch file.
../Makefile:59: recipe for target '../O.Common/snl.bnf' failed
make[3]: *** [../O.Common/snl.bnf] Error 1
make[3]: Leaving directory
'D:/synApps-testing/VS10/3.15/synApps/support/seq-2-2-3/src/snc/O.windows-x64-static'
D:/synApps-testing/VS10/3.15/base-3.15.4/configure/RULES_ARCHS:61:
recipe for target 'install.windows-x64-static' failed
make[2]: *** [install.windows-x64-static] Error 2
make[2]: Leaving directory
'D:/synApps-testing/VS10/3.15/synApps/support/seq-2-2-3/src/snc'
D:/synApps-testing/VS10/3.15/base-3.15.4/configure/RULES_DIRS:88: recipe
for target 'snc.install' failed
make[1]: *** [snc.install] Error 2
make[1]: Leaving directory
'D:/synApps-testing/VS10/3.15/synApps/support/seq-2-2-3/src'
for target 'src.install' failed
make: *** [src.install] Error 2
The error occurs on the call to lemon.exe, so the rename of the temp
file never happens. The O.windows-x64-static dir contains an empty
snl.bnf.tmp file. Issuing "make" a second time no longer allows the
build to succeed; it fails on the same line as the first call to "make".
Kevin
On 9/7/16 10:18 AM, Benjamin Franksen wrote:
> Hi
> just back from holidays. Perhaps it helps to replace
> $(COMMON_DIR)/snl.bnf: snl.lem
> $(LEMON) o=. -g $< > $@
> with
> $(LEMON) o=. -g $< > $(@F).tmp
> $(MV) $(@F).tmp $@
> which would also make parallel builds more reliable?
> Cheers
> Ben
> On 18.08.2016 18:13, Kevin Peterson wrote:
>> I doesn't appear that this build error is due to a bug in make. I'm
>> using the following to build seq-2-2-3:
>> Windows 7 (64-bit)
>> Visual Studio 2010 Professional & Visual Studio 2015 Community Edition
>> Make 4.1 (from the EPICS web site)
>> Strawberry perl 5.20.3001
>> I see the build error when using base-3.15.4, but NOT when using
>> base-3.14.12.5. Issuing "make" a second time does allow the build to
>> run to completion.
>> I'm hoping someone with knowledge of the changes to build rules between
>> base 3.14 and 3.15 can suggest a fix.
>> Kevin
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Andrew Johnson
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
RE: link: invalid option -- n.....make[2]: *** [install.windows-x64] Error 2 Mark Rivers
Re: github hides accounts Kevin Peterson
<2016>
<2016>
ANJ, 07 Sep 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
