On 09/07/2016 02:46 PM, Kevin Peterson wrote:
> That change doesn't eliminate the build error:
> "Installing created executable ../../../bin/windows-x64-static/snc.exe"
> ../Makefile:59: PATH_FILTER is deprecated; used for
> ../../../bin/windows-x64-static/lemon.exe
> ../../../bin/windows-x64-static/lemon.exe o=. -g ../snl.lem > snl.bnf.tmp
> '..' is not recognized as an internal or external command,
> operable program or batch file.
> ../Makefile:59: recipe for target '../O.Common/snl.bnf' failed
>> $(COMMON_DIR)/snl.bnf: snl.lem
>> $(LEMON) o=. -g $< > $(@F).tmp
>> $(MV) $(@F).tmp $@
The problem is that the Windows command shell doesn't like relative
paths to executables, unless they use backwards slashes. Try replacing
$(LEMON) with $(abspath $(LEMON)) to see if that helps.
- Andrew
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Kevin Peterson
- Re: Building SEQ 2.2.3, Windows, EPICS Base 3-15-2 Benjamin Franksen
Re: github hides accounts Kevin Peterson
RE: github hides accounts Mark S. Engbretson
<2016>
<2016>
ANJ, 07 Sep 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
