1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Lambda EMS mismatch errors
To: Rod Nussbaumer <[email protected]>
Cc: Yujong Kim <[email protected]>, [email protected]
Date: Thu, 25 Oct 2012 18:21:06 -0700
That kind of looks like the telnet newline sequence.
Can you put the terminal server into a different mode?
On Oct 25, 2012, at 6:03 PM, Rod Nussbaumer <[email protected]> wrote:
> Tony:
> It looks like your instrument returns some peculiar EOL terminators:
> <0a><0d><00><0a><0a>
> which is a linefeed, carriage return, a null byte and two more linefeeds.
> These last two are probably what you describe as 'the double space between commands in telnet'. You can possibly use 'LF LF' as your input terminator, and swallow up the 'LF CR \0' using "%*c" in your protocol. I'm not sure what effect a null byte has on processing and terminating input.
> I will guess that your sample output was using 'LF' as the input terminator. This would terminate reading on the first LF, and then leave the CR - 00 - LF -LF remaining in the stream for processing. Alternatively, you migh be able to use multiple 'in' commands in your protocols, each one swallowing up more and more of the line terminator.
> It would be so much simpler if instruments could just get these things right in the first place.
>   ---   rod.
> On 10/25/2012 04:44 PM, Anthony Andrews wrote:
>> Thanks for the advice!
>> The echo command was causing those problems.
>> To solve that, I made two records and two protocols to set SB (echo) and
>> SM (command prompt length) to 0.
>> So, now I can get the current and voltage to change slowly.
>> However, in MEDM I have to hit enter quite a lot to get the voltage to
>> change and the current doesn't want to change very fast either.
>> I also get another kind of mismatch error in the output which I think is
>> a possible cause for the current and voltage changing slowly.
>> ## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
>> ## EPICS Base built Oct 17 2012
>> 2012/10/25 16:46:37.111 10.1.1.1:4008 <http://10.1.1.1:4008> write 3
>> SR\n
>> 2012/10/25 16:46:37.613 10.1.1.1:4008 <http://10.1.1.1:4008> write 4
>> SB0\r
>> 2012/10/25 16:46:37.613 10.1.1.1:4008 <http://10.1.1.1:4008> write 9
>> PV38.000\n
>> iocRun: All initialization complete
>> ## Start any sequence programs
>> #seq sncxxx,"user=tonyHost"
>> epics> 2012/10/25 16:46:38.112 10.1.1.1:4008 <http://10.1.1.1:4008> write 3
>> MC\n
>> 2012/10/25 16:46:38.685 10.1.1.1:4008 <http://10.1.1.1:4008> read 10
>> 0.004\r\000\n\n>
>> 2012/10/25 16:46:38.685 10.1.1.1:4008 <http://10.1.1.1:4008> write 4
>> SM0\r
>> 2012/10/25 16:46:38.685 10.1.1.1:4008 <http://10.1.1.1:4008> write 9
>> PC 0.000\n
>> 2012/10/25 16:46:38.685 10.1.1.1:4008 <http://10.1.1.1:4008> write 3
>> MV\n
>> 2012/10/25 16:46:38.702 10.1.1.1:4008 <http://10.1.1.1:4008> read 5
>> \r\000\n\n>
>> 2012/10/25 16:46:38.702 P8 LamEMS:ADDR:VOLT_M: Input "<0d><00>" does not
>> match format %6f
>> 2012/10/25 16:46:39.112 10.1.1.1:4008 <http://10.1.1.1:4008> write 3
>> MC\n
>> 2012/10/25 16:46:39.684 10.1.1.1:4008 <http://10.1.1.1:4008> read 10
>> 0.004\r\000\n\n>
>> I've also attached a screenshot of telnet, and updated protocol and
>> database file.
>> I think that the error here may have something to do with the double
>> space between commands in telnet, but, I'm not sure.
>> I'm also not sure what <0d><00> means here.
>> So far I've tried different terminators, terminators in multiple places
>> (inside protocols and at the top), and I've tried to represent the
>> "\r\000\n\n>" at the end of each read inside of the protocol.
>> But, I can't seem to figure it out.
>> I think that if I can fix this error, the current and voltage may change
>> a bit faster as well.
>> If anyone has any advice on how to get rid of these last error it would
>> be very helpful.
>> Thank you.
>> On Wed, Oct 24, 2012 at 7:05 AM, Rod Nussbaumer <[email protected]
>> <mailto:[email protected]>> wrote:
>>    Tony:
>>    It looks like the power supply echoes the commands that are sent to
>>    it. You will need to craft your protocol(s) to read these echoed
>>    commands, or there may be a way to turn off the echoes.
>>    Rod Nussbaumer
>>    ISAC Controls, TRIUMF
>>    Vancouver, Canada
>>    On 10/23/2012 05:17 PM, Anthony Andrews wrote:
>>        ##############################__##############################__###############
>>        epics> 2012/10/23 18:05:13.924 xxx.yyy.zzz.aaa:4008 write 3
>>        MC\n
>>        2012/10/23 18:05:13.936 xxx.yyy.zzz.aaa:4008 read 5
>>        MC\n\r\000
>>        2012/10/23 18:05:13.936 P8 LamEMS:ADDR:CURR_M: Input "MC"
>>        mismatch after
>>        0 bytes
>>        2012/10/23 18:05:13.936 P8 LamEMS:ADDR:CURR_M: got "MC" where
>>        "Current =
>>        " was expected
>>        2012/10/23 18:05:13.936 xxx.yyy.zzz.aaa:4008 write 3
>>        MV\n
Eric Norum
[email protected]
Lambda EMS mismatch errors Anthony Andrews
Re: Lambda EMS mismatch errors Rod Nussbaumer
Re: Lambda EMS mismatch errors Anthony Andrews
Prev: Re: Lambda EMS mismatch errors Rod Nussbaumer
Next: waveform record: how its VAL get data? any potential memory leak? ... Jack Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: installing EPICS James Bryant
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
