The echo command was causing those problems. To solve that, I made two records and two protocols to set SB (echo) and SM (command prompt length) to 0. So, now I can get the current and voltage to change slowly. However, in MEDM I have to hit enter quite a lot to get the voltage to change and the current doesn't want to change very fast either. I also get another kind of mismatch error in the output which I think is a possible cause for the current and voltage changing slowly. ############################################################################ ## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$ ## EPICS Base built Oct 17 2012 ############################################################################ 2012/10/25 16:46:37.111 10.1.1.1:4008 write 3 SR\n 2012/10/25 16:46:37.613 10.1.1.1:4008 write 4 SB0\r 2012/10/25 16:46:37.613 10.1.1.1:4008 write 9 PV38.000\n iocRun: All initialization complete ########################################################################### ## Start any sequence programs #seq sncxxx,"user=tonyHost" epics> 2012/10/25 16:46:38.112 10.1.1.1:4008 write 3 MC\n 2012/10/25 16:46:38.685 10.1.1.1:4008 read 10 0.004\r\000\n\n> 2012/10/25 16:46:38.685 10.1.1.1:4008 write 4 SM0\r 2012/10/25 16:46:38.685 10.1.1.1:4008 write 9 PC 0.000\n 2012/10/25 16:46:38.685 10.1.1.1:4008 write 3 MV\n 2012/10/25 16:46:38.702 10.1.1.1:4008 read 5 \r\000\n\n> 2012/10/25 16:46:38.702 P8 LamEMS:ADDR:VOLT_M: Input "<0d><00>" does not match format %6f 2012/10/25 16:46:39.112 10.1.1.1:4008 write 3 MC\n 2012/10/25 16:46:39.684 10.1.1.1:4008 read 10 0.004\r\000\n\n> I've also attached a screenshot of telnet, and updated protocol and database file. I think that the error here may have something to do with the double space between commands in telnet, but, I'm not sure. I'm also not sure what <0d><00> means here. So far I've tried different terminators, terminators in multiple places (inside protocols and at the top), and I've tried to represent the "\r\000\n\n>" at the end of each read inside of the protocol. But, I can't seem to figure it out. I think that if I can fix this error, the current and voltage may change a bit faster as well. If anyone has any advice on how to get rid of these last error it would be very helpful. Thank you. On Wed, Oct 24, 2012 at 7:05 AM, Rod Nussbaumer <[email protected]> wrote: Tony: Attachment:
telnet.png Attachment:
EMS_01.vdb Attachment:
EMS_01.proto
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
