1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: installing EPICS
To: [email protected]
Date: Tue, 23 Oct 2012 23:59:07 -0400
Ive been trying all types of ways to install EPICS on my mac OS 10.8.2 with no luck... I have a laundry list of problems but Ive been informed that the first problem to tackle is getting epics base working... every time i try to run 'python setup.py install' from the epics base directory it gives me this code :
new-host:base-3.14.12.2 jamesbryant$ export EPICS_BASE=/Users/jamesbryant/Desktop/base-3.14.12.2
new-host:base-3.14.12.2 jamesbryant$ python setup.py install
python: can't open file 'setup.py': [Errno 2] No such file or directory
new-host:base-3.14.12.2 jamesbryant$ python3 setup.py install
/Library/Frameworks/Python.framework/Versions/3.2/Resources/Python.app/Contents/MacOS/Python: can't open file 'setup.py': [Errno 2] No such file or directory
new-host:base-3.14.12.2 jamesbryant$ sudo setup.py install
Password:
sudo: setup.py: command not found
# before this I input:
new-host:base-3.14.12.2 jamesbryant$ export EPICS_HOST_ARCH=darwin-x86
new-host:base-3.14.12.2 jamesbryant$ make
# ... and it spit out a bunch of code, which ended with:
mkdir ../../../lib/perl/5.12.4
mkdir ../../../lib/perl/5.12.4/darwin-thread-multi-2level
Installing script ../../../bin/darwin-x86/cainfo.pl
Installing script ../../../bin/darwin-x86/caput.pl
Installing script ../../../bin/darwin-x86/caget.pl
Installing script ../../../bin/darwin-x86/capr.pl
Installing script ../../../bin/darwin-x86/camonitor.pl
rm -f CA.html
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
../CA.pm pod syntax OK.
Installing html ../../../html/./CA.html
rm CA.html
any ideas???
- Thanks!
Re: installing EPICS J. Lewis Muir
Re: installing EPICS Matt Newville
Prev: Lambda EMS mismatch errors Anthony Andrews
Next: Re: Lambda EMS mismatch errors Fabian S.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Lambda EMS mismatch errors Eric Norum
Next: Re: installing EPICS J. Lewis Muir
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
