1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem installing SDDS on OS X 10.5.1
To: [email protected]
Date: Wed, 28 Nov 2007 11:43:16 -0800
Oops, so this is a problem with the SDDS make files?
Strange thing is I was able to compile it in 10.4 without much difficulty...
Bertrand
On Nov 28, 2007, at 11:36 AM, Bob Soliday wrote:
Bertrand H.J. Biritz wrote:
Interesting, on 10.5 I have both a /usr/X11 and /usr/X11R6 directory which both contain the necessary files.
I checked the config files and they are both fine - pointing to / usr/X11R6. I did see they don't support Mac Port though, since openmotif is coming from /sw/include and /sw/lib which is Fink.
Were you are to successfully build SDDS on your 10.5?
Bertrand
There are multiple problems here. First it should not be linking to Xpm in the first place on Darwin. And second it is only looking in / usr/lib for the the Xpm library.
--Bob
Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Re: Problem installing SDDS on OS X 10.5.1 Bob Soliday
Re: Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Prev: Re: Missing JCA web page? Andrew Johnson
Next: RE: JCA using problem Guobao Shen (KEK)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem installing SDDS on OS X 10.5.1 Bob Soliday
Next: Re: Problem installing SDDS on OS X 10.5.1 J. Lewis Muir
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
