1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem installing SDDS on OS X 10.5.1
To: [email protected]
Date: Wed, 28 Nov 2007 12:21:34 -0500
On 11/28/07 12:01 PM, Bertrand H.J. Biritz wrote:
So it is a Mac Port versus Fink problem?
Bertrand
It looks like it's not finding your Xpm library. On my Mac OS X 10.5 system, it exists at /usr/X11/lib:
$ ls -1 /usr/X11/lib/libXpm*
/usr/X11/lib/libXpm.4.11.0.dylib
/usr/X11/lib/libXpm.4.dylib
/usr/X11/lib/libXpm.dylib
/usr/X11/lib/libXpm.la
Maybe your extensions/config or extensions/configure files are not set up correctly to include this location? For example, in extensions/config/CONFIG_SITE.Host.Darwin and extensions/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc, check the X11_LIB, X11_INC, XPM_LIB, and XPM_INC variables. Or maybe the SDDS build files are not picking this location up correctly for the build?
-lewis
On Nov 28, 2007, at 8:47 AM, Bob Soliday wrote:
When I build SDDS on OSX it does not attempt to build the gd library because I already have it installed. The Makefile in the SDDS directory looks for /sw/lib/libgd.a and /sw/lib/libgd.dylib and if they are found it will use the system library instead of building a new one. The same goes for libpng and libtiff
--Bob
Dear Tech talk,
it is I once more, the early adopter of OS X 10.5 :)
After the initial help of getting base to build (thanks once more for the incredible prompt turn around) I didn't run into any problem building the Alarm Handler nor even MEDM (thought I would with the later).
Now I am trying to build SDDS - latest version downloaded from their website.
I run into the following error:
make -C O.darwin-ppc -f ../Makefile TOP=../../../.. T_A=darwin-ppc install
/usr/bin/c++ -o libgd.3.14.9.dylib -dynamiclib -flat_namespace -undefined suppress -install_name /usr/local/bin/epics/extensions/lib/darwin-ppc/libgd.3.14.9.dylib -compatibility_version 3.14 -current_version 3.14.9 -L/usr/local/bin/epics/extensions/lib/darwin-ppc -L/opt/local/lib/ gd.o gdfx.o gd_security.o gd_gd.o gd_gd2.o gd_io.o gd_io_dp.o gd_gif_in.o gd_gif_out.o gd_io_file.o gd_io_ss.o gd_png.o gd_ss.o gd_topal.o gd_wbmp.o gdcache.o gdfontg.o gdfontl.o gdfontmb.o gdfonts.o gdfontt.o gdhelpers.o gdkanji.o gdtables.o gdxpm.o wbmp.o gdft.o gd_jpeg.o -lpng -lz -lXpm -lreadline -lm -lgcc
ld: library not found for -lXpm
collect2: ld returned 1 exit status
make[2]: *** [libgd.3.14.9.dylib] Error 1
make[1]: *** [install.darwin-ppc] Error 2
make: *** [gd.install] Error 2
Now, when I used Mac Ports (switched from Fink to try it out) to install Xpm it get the error message:
Activating xpm 3.4k_0
Error: Target org.macports.activate returned: Image error: /usr/X11/bin/cxpm already exists and does not belong to a registered port. Unable to activate port xpm.
Error: Status 1 encountered during processing.
Naturally my question is how I get SDDS to build?
My ultimate goal is to get the VLinac to run on my machine. It is really a great way to test if everything is working and to try out new things.
Thanks once more,
Bertrand
Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Re: Problem installing SDDS on OS X 10.5.1 Bob Soliday
Re: Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Prev: Re: Problem installing SDDS on OS X 10.5.1 Bob Soliday
Next: Missing JCA web page? Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
