So it is a Mac Port versus Fink problem?
Bertrand
On Nov 28, 2007, at 8:47 AM, Bob Soliday wrote:
When I build SDDS on OSX it does not attempt to build the gd library
because I already have it installed. The Makefile in the SDDS
directory looks for /sw/lib/libgd.a and /sw/lib/libgd.dylib and if
they are found it will use the system library instead of building a
new one. The same goes for libpng and libtiff
--Bob
Bertrand H.J. Biritz wrote:
Dear Tech talk,
it is I once more, the early adopter of OS X 10.5 :)
After the initial help of getting base to build (thanks once more
for the incredible prompt turn around) I didn't run into any
problem building the Alarm Handler nor even MEDM (thought I would
with the later).
Now I am trying to build SDDS - latest version downloaded from
their website.
I run into the following error:
make -C O.darwin-ppc -f ../Makefile TOP=../../../.. T_A=darwin-ppc
install
/usr/bin/c++ -o libgd.3.14.9.dylib -dynamiclib -flat_namespace -
undefined suppress -install_name /usr/local/bin/epics/extensions/
lib/darwin-ppc/libgd.3.14.9.dylib -compatibility_version 3.14 -
current_version 3.14.9 -L/usr/local/bin/epics/extensions/lib/darwin-
ppc -L/opt/local/lib/ gd.o gdfx.o gd_security.o
gd_gd.o gd_gd2.o gd_io.o gd_io_dp.o gd_gif_in.o gd_gif_out.o
gd_io_file.o gd_io_ss.o gd_png.o gd_ss.o gd_topal.o gd_wbmp.o
gdcache.o gdfontg.o gdfontl.o gdfontmb.o gdfonts.o gdfontt.o
gdhelpers.o gdkanji.o gdtables.o gdxpm.o wbmp.o gdft.o gd_jpeg.o -
lpng -lz -lXpm -lreadline -lm -lgcc
ld: library not found for -lXpm
collect2: ld returned 1 exit status
make[2]: *** [libgd.3.14.9.dylib] Error 1
make[1]: *** [install.darwin-ppc] Error 2
make: *** [gd.install] Error 2
Now, when I used Mac Ports (switched from Fink to try it out) to
install Xpm it get the error message:
Activating xpm 3.4k_0
Error: Target org.macports.activate returned: Image error: /usr/X11/
bin/cxpm already exists and does not belong to a registered port.
Unable to activate port xpm.
Error: Status 1 encountered during processing.
Naturally my question is how I get SDDS to build?
My ultimate goal is to get the VLinac to run on my machine. It is
really a great way to test if everything is working and to try out
new things.
Thanks once more,
Bertrand
- Re: Problem installing SDDS on OS X 10.5.1 Bob Soliday
- Re: Problem installing SDDS on OS X 10.5.1 J. Lewis Muir
- Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Re: MVME6100 or 7100 Oleg Makarov
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
