When I build SDDS on OSX it does not attempt to build the gd library
because I already have it installed. The Makefile in the SDDS directory
looks for /sw/lib/libgd.a and /sw/lib/libgd.dylib and if they are found
it will use the system library instead of building a new one. The same
goes for libpng and libtiff
--Bob
Bertrand H.J. Biritz wrote:
Dear Tech talk,
it is I once more, the early adopter of OS X 10.5 :)
After the initial help of getting base to build (thanks once more for
the incredible prompt turn around) I didn't run into any problem
building the Alarm Handler nor even MEDM (thought I would with the later).
Now I am trying to build SDDS - latest version downloaded from their
website.
I run into the following error:
make -C O.darwin-ppc -f ../Makefile TOP=../../../.. T_A=darwin-ppc install
/usr/bin/c++ -o libgd.3.14.9.dylib -dynamiclib -flat_namespace
-undefined suppress -install_name
/usr/local/bin/epics/extensions/lib/darwin-ppc/libgd.3.14.9.dylib
-compatibility_version 3.14 -current_version 3.14.9
-L/usr/local/bin/epics/extensions/lib/darwin-ppc
-L/opt/local/lib/ gd.o gdfx.o gd_security.o gd_gd.o gd_gd2.o
gd_io.o gd_io_dp.o gd_gif_in.o gd_gif_out.o gd_io_file.o gd_io_ss.o
gd_png.o gd_ss.o gd_topal.o gd_wbmp.o gdcache.o gdfontg.o gdfontl.o
gdfontmb.o gdfonts.o gdfontt.o gdhelpers.o gdkanji.o gdtables.o gdxpm.o
wbmp.o gdft.o gd_jpeg.o -lpng -lz -lXpm -lreadline -lm -lgcc
ld: library not found for -lXpm
collect2: ld returned 1 exit status
make[2]: *** [libgd.3.14.9.dylib] Error 1
make[1]: *** [install.darwin-ppc] Error 2
make: *** [gd.install] Error 2
Now, when I used Mac Ports (switched from Fink to try it out) to install
Xpm it get the error message:
Activating xpm 3.4k_0
Error: Target org.macports.activate returned: Image error:
/usr/X11/bin/cxpm already exists and does not belong to a registered
port. Unable to activate port xpm.
Error: Status 1 encountered during processing.
Naturally my question is how I get SDDS to build?
My ultimate goal is to get the VLinac to run on my machine. It is really
a great way to test if everything is working and to try out new things.
Thanks once more,
Bertrand
- Re: Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
- Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Re: MVME6100 or 7100 Till Straumann
Re: JCA using problem J. Lewis Muir
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
