Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: Re: Init pv properly
To: Andrew Johnson <anj@aps.anl.gov>, "Arnold, Ned D." <nda@anl.gov>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Fri, 14 Apr 2017 18:00:17 +0100
Thanks that is exactly what i am going to do ( i was doing that already but now i will use INP field instead of VAL and add the DTYP as well)
On 14-04-2017 17:56, Andrew Johnson wrote:
On 04/14/2017 11:49 AM, Miguel wrote:
It does work yes. Just wondering if there was a more suitable one. Thanks
For a numeric parameter that can be set by the user, the best record
type to use is usually the ao record (or the longout for integers); you
can then use the DRHV/DRVL fields to limit the range of values that will
be accepted, and/or the IVOA field along with alarm limits to control
what happens for bad values:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Common#Invalid_Alarm_Output_Action
- Andrew
Init pv properly Miguel
RE: Init pv properly Arnold, Ned D.
Re: Init pv properly Miguel
Re: Init pv properly Andrew Johnson
Prev: Re: Init pv properly Andrew Johnson
Next: RE: Writing Area Detector Monitor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Next: RE: Init pv properly Mooney, Tim M.
ANJ, 14 Apr 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
