1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Init pv properly
To: [email protected]
Date: Fri, 14 Apr 2017 17:18:49 +0100
Hello,
I would like to create a Pv that at the epics start up does not have any specific value or one forced by me.
For example i would like to have a string that its initial state is not really important (no experience). Like:
record(stringin , "$(user):ExperienceString"){
    info(autosaveFields, "VAL")        #autosave
    field(VAL, "no experience")
    field(DESC, "anotar estados da experiencia")
Where ill change this afterwrds manually when it will be important.
The problem is that i would not like it to be instantiated as an undefined pv. Changing the VAL is the most appropriated method? I tought about changin UDF to 0 but did not work.
The same for a integer pv. Wich kind of pv should i use and how should i instantiate it?
Thanks a lot,
MiguelB
RE: Init pv properly Arnold, Ned D.
RE: Init pv properly Mooney, Tim M.
Prev: RE: Writing Area Detector Monitor Mark S. Engbretson
Next: RE: Init pv properly Arnold, Ned D.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: ICALEPCS 2017 abstract submission deadline James Rezende Piton
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
