Why doesn't a ai, ao, or calc work for this purpose? Making field(DTYP, "Soft") makes it not tied to any hardware ...
Ned
Yes you are right. I was going to say that that would not help me because i have the autosave and the PINI would overwrite it, but that actually not true. I got this wrong the first time I did it.
Thanks 4 the help.
By the way, what kind of record should i be using for a decimal value that is not either a ai, ao or calc. I mean, it is a value that is only changed by the user manually.Like a setpoint or something similar.
On 14-04-2017 17:24, Arnold, Ned D. wrote:
>The problem is that i would not
like it to be instantiated as an
>undefined pv.
If I understand correctly, I think all you need is the PINI field set true ...
record(stringin , "$(user):ExperienceString"){
info(autosaveFields, "VAL") #autosave
field(VAL, "no experience")
field(PINI,"YES")
field(DESC, "anotar estados da experiencia")
Ned
[email protected] [[email protected]] on behalf of Miguel [[email protected]]
Sent: Friday, April 14, 2017 11:18 AM
To:
[email protected]
Subject: Init pv properly
Hello,
I would like to create a Pv that at the epics start up does not have any
specific value or one forced by me.
For example i would like to have a string that its initial state is not
really important (no experience). Like:
Where ill change this afterwrds manually when it will be important.
The problem is that i would not like it to be instantiated as an
undefined pv.
Changing the VAL is the most appropriated method? I tought about changin
UDF to 0 but did not work.
The same for a integer pv. Wich kind of pv should i use and how should i
instantiate it?
Thanks a lot,
MiguelB
- Re: Init pv properly Miguel
- Init pv properly Miguel
- RE: Init pv properly Arnold, Ned D.
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Andrew Johnson
<2017>
<2017>
ANJ, 21 Dec 2017 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
