1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory"
To: lzf neu <[email protected]>
Date: Fri, 17 Feb 2017 10:57:41 -0500
FYI, my notes on build and setup of EDM (and necessary dependencies)
http://mdavidsaver.github.io/epics-doc/epics-starting.html#_edm
On 02/16/2017 09:19 PM, lzf neu wrote:
> Hi,
> Actually, I look up the README.install file in edm folder, and find
> giflib, zlib, and libpng packages have been installed  on my fedora20-64
> bit system. But the problem still exists.
> Thanks
> *发件人:* Mike Westfall <[email protected]>
> *发送时间:* 2017年2月16日 20:50
> *收件人:* lzf neu
> *抄送:* [email protected]
> *主题:* Re: EDM compiling problems
> Looks like you need to install libpng-devel
> *发件人:* lzf neu <[email protected]>
> *发送时间:* 2017年2月16日 8:34
> *收件人:* [email protected]
> *抄送:* lzf neu
> *主题:* EDM compiling problems
> Hi,
> I visit the directory /extensions/src/edm/setup/ and run ./setup.sh to
> compile EDM, an error occured and gives the following information:
> Edm component file is /home/user/epics/extensions/src/edm/setup/edmObjects
> /home/user/epics/extensions/src/edm/imagelib/O.linux-x86_64/lib605432d2-f29d-11d2-973b-00104b8742df.so:
> When running EDM, the software cannot display pictures and gives the
> following error messages:
> Error creating object "activePngClass"
> Error creating object "cfcf6c8a_dbeb_11d2_8a97_00104b8742df"
> However, I have already installed giflib, giflib-devel, libNX_Xtst,
> libXtst, libXtst-devel packages and set env .
> export EDMBASE=/home/user/epics/extensions/src/edm
> export EDMPVOBJECTS=/home/user/epics/extensions/src/edm/setup
> export EDMOBJECTS=/home/user/epics/extensions/src/edm/setup
> export EDMHELPFILES=/home/user/epics/extensions/src/edm/helpFiles
> export EDMFILES=/home/user/epics/extensions/src/edm/edmMain
> Do I miss something?
> Could you give me some advice thanks in advance.
EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" lzf neu
Prev: Linux System Administrator position Hartman, Steven M.
Next: Leybold Combivac IT23 Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Westfall
Next: CA.Client.Exception "Virtual circuit disconnect" source file: .../cac.pp line 1215 Raquel Pérez Lázaro
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
