1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory"
To: lzf neu <[email protected]>
Date: Fri, 17 Feb 2017 11:44:43 -0300
On Thu, Feb 16, 2017 at 11:19 PM, lzf neu <[email protected]> wrote:
I visit the directory /extensions/src/edm/setup/ and run ./setup.sh to compile EDM, an error occured and gives the following information:
setup.sh does not compile EDM. That script is for setting environment variables before you run EDM.
To compile EDM, you should type 'make' in the EDM top directory (../extensions/src/edm).
After that, you should examine setup.sh and make any modifications necessary for your specific EPICS installation.
Mike Westfall
Control Systems Software Engineer
EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" lzf neu
Prev: Archive-engine compiled for linux-arm (Raspberry Pi) Miguel
Next: Linux System Administrator position Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" lzf neu
Next: Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Davidsaver
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
