Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Subject: CA.Client.Exception "Virtual circuit disconnect" source file: .../cac.pp line 1215
To: tech-talk@aps.anl.gov
Date: Fri, 17 Feb 2017 11:57:19 +0100
Title: Raquel Pérez Lázaro
Hello,
I am developing a C program that runs several CA clients taks connecting to several IOCs.
It seems that it works right when there is only one CA client but when there are two or more clients I am getting the following CA client exception displayed:
I have looked at line 1215  of the referenced "cac.cpp" file,  you can see in the captured picture below, but it does not get me too much information about what is happening:
Does someone have any idea about what does it happen?,  Why the virtual circuit is disconnected?
As result of it, the second CA client program is not able any more to connect  and  to monitor the process variables.
Any solution about how to solve this issue?
Thank you very much in advance,
 R. Perez
Raquel Pérez Lázaro
System Engineer
IXION
Julián Camarillo, 21B – 3º
28037 Madrid, España
Phone: +34 91 440 18 33
Ph. dir: +34 91 440 18 48
FAX: +34 91 30 45 410
rperez@ixion.es
http://www.ixion.es
Prev: Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Next: Archive-engine compiled for linux-arm (Raspberry Pi) Miguel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <2017
Prev: Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Davidsaver
ANJ, 17 Feb 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
