1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: How access to an array value from a process variable using ca_array_get()?
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Fri, 17 Feb 2017 10:00:33 +0100
Title: Raquel Pérez Lázaro
Hello,
Thank you very much for your prompt answer.
I found a really useful example in the CA Reference Manual.
R. Perez
El 16.02.2017 a las 5:48 PM, J. Lewis Muir escribió:
On 02/15, Raquel Pérez Lázaro wrote:
Hello,
I am trying to read and write to an array value from a process
variable using ca_array_get() function, but it is no clear for me
how I should use this function in order to access to each element of
the array and print its value.
I would appreciate an example.
Thank you,
R. Perez
See the documentation for ca_array_get in the CA Reference Manual [1].
It suggests looking a "caExample.c in the example application created
by makeBaseApp.pl."  You can also look at the source code for the caget
program in EPICS Base 3.14 [2] (and 3.15 [3]) which has a caget function
which uses ca_array_get_callback or ca_array_get and also iterates over
the elements of the array and prints their values.
Lewis
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#ca_get
[2] http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/catools/caget.c
[3] http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/ca/client/tools/caget.c
Raquel Pérez Lázaro
System Engineer
IXION
Julián Camarillo, 21B – 3º
28037 Madrid, España
Phone: +34 91 440 18 33
Ph. dir: +34 91 440 18 48
FAX: +34 91 30 45 410
[email protected]
http://www.ixion.es
How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Re: How access to an array value from a process variable using ca_array_get()? J. Lewis Muir
Prev: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" lzf neu
Next: CA.Client.Exception "Virtual circuit disconnect" source file: .../cac.pp line 1215 Raquel Pérez Lázaro
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: How access to an array value from a process variable using ca_array_get()? J. Lewis Muir
Next: IOC Connecting Problem Pilkyu Jung
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
