1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory"
To: "[email protected]" <[email protected]>, Mike Westfall <[email protected]>, lzf neu <[email protected]>
Date: Fri, 17 Feb 2017 02:19:29 +0000
Actually, I look up the README.install file in edm folder, and find giflib, zlib, and libpng packages have been installed  on my fedora20-64 bit system. But the problem still exists.
Thanks
发件人: Mike Westfall <[email protected]>
发送时间: 2017年2月16日 20:50
收件人: lzf neu
抄送: [email protected]
主题: Re: EDM compiling problems
Looks like you need to install libpng-devel
发件人: lzf neu <[email protected]>
发送时间: 2017年2月16日 8:34
收件人: [email protected]
抄送: lzf neu
主题: EDM compiling problems
I visit the directory /extensions/src/edm/setup/ and run ./setup.sh to compile EDM, an error occured and gives the following information:
Edm component file is /home/user/epics/extensions/src/edm/setup/edmObjects
/home/user/epics/extensions/src/edm/imagelib/O.linux-x86_64/lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory
When running EDM, the software cannot display pictures and gives the following error messages:
Error creating object "activePngClass"
Error creating object "cfcf6c8a_dbeb_11d2_8a97_00104b8742df"
However, I have already installed giflibgiflib-devellibNX_Xtst, libXtst, libXtst-devel packages and set env .
export EDMBASE=/home/user/epics/extensions/src/edm
export EDMPVOBJECTS=/home/user/epics/extensions/src/edm/setup
export EDMOBJECTS=/home/user/epics/extensions/src/edm/setup
export EDMHELPFILES=/home/user/epics/extensions/src/edm/helpFiles
export EDMFILES=/home/user/epics/extensions/src/edm/edmMain
Do I miss something?
Could you give me some advice thanks in advance.
Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Westfall
Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Davidsaver
Prev: Re: EDM compiling problems Mike Westfall
Next: Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Notes on building EDM for Linux Mint 17 bob.anderson
Next: Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Westfall
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
