1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC Connecting Problem
To: [email protected]
Date: Thu, 16 Feb 2017 06:15:18 -0800
Pilkyu:
In your telnet connection, you use port 5024, but in the asyn port connection, you are attempting to use port 5025. This is quite likely one cause of your problem.
Rod Nussbaumer
TRIUMF
Vancouver, Canada
On 02/15/2017 10:29 PM, Pilkyu Jung wrote:
Hi all,
First of all, I am trying to connect from a oscilloscope which name is
Agilent Technologies DSO-X 3052A (500 MHz 4 GSa/s) to IOC.
As you can see in the
manual(http://literature.cdn.keysight.com/litweb/pdf/75019-97073.pdf ,
http://www.keysight.com/upload/cmc_upload/All/3000_series_prog_guide.pdf),
this oscilloscope support a few ways (e.g. the IO Library, Telnet
Sockets, and using Browser Web Control) for sending SCPI.
However, When I connect to IOC, I got a problem. Until now, I just
connected only adjust IP address in st.cmd.
Like this,
drvAsynIPPortConfigure("P1",169.254.90.3:5025,0,0,0)
When I connect by telnet, it is done successfully (please check the
Screenshot...image file).
I don't know why this device can't be connected to IOC in this case.
Definitely I am done with this way before, but now I can't.
Here is my question,
1. Normally, when you connect from device to IOC, what kind of method use?
2. In my case, How can I connect to IOC?
Best Regards,
Pilkyu Jung
Re: IOC Connecting Problem Pilkyu Jung
Prev: RE: Problem compiling areaDetector-2-5 Mark Rivers
Next: Notes on building EDM for Linux Mint 17 bob.anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: IOC Connecting Problem Pilkyu Jung
Next: Re: IOC Connecting Problem Pilkyu Jung
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
