1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Subject: IOC Connecting Problem
To: <[email protected]>
Date: Thu, 16 Feb 2017 15:29:53 +0900
Hi all,
First of all, I am trying to connect from a oscilloscope which name is Agilent Technologies DSO-X 3052A (500 MHz 4 GSa/s) to IOC.
As you can see in the manual(http://literature.cdn.keysight.com/litweb/pdf/75019-97073.pdf , http://www.keysight.com/upload/cmc_upload/All/3000_series_prog_guide.pdf),
this oscilloscope support a few ways (e.g. the IO Library, Telnet Sockets, and using Browser Web Control) for sending SCPI.
However, When I connect to IOC, I got a problem. Until now, I just connected only adjust IP address in st.cmd.
Like this,
drvAsynIPPortConfigure("P1",169.254.90.3:5025,0,0,0)
When I connect by telnet, it is done successfully (please check the Screenshot...image file).
I don't know why this device can't be connected to IOC in this case. Definitely I am done with this way before, but now I can't.
Here is my question,
1. Normally, when you connect from device to IOC, what kind of method use?
2. In my case, How can I connect to IOC?
Best Regards,
Pilkyu Jung
Attachment: Screenshot from 2017-02-15 18_16_44.png
Description: PNG image
Re: IOC Connecting Problem Florian Feldbauer
Re: IOC Connecting Problem Rod Nussbaumer
Prev: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Next: Re: IOC Connecting Problem Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024
Prev: Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
