1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: OS X edm/medm openmotif woes
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Cc: Epics <[email protected]>
Date: Thu, 17 Nov 2016 09:43:39 -0600
On 11/17, Wang Xiaoqiang (PSI) wrote:
> Hi Lewis,
> After checking, my medm is linked only to MacPorts libraries.
Hi, Xiaoqiang.
OK, thanks for confirming.
> As you said, the key issue is the flat_namespace flag. Luckily
> Macports handles that automatically if the xorg-libXt is installed as
> a dependency to openmotif.
I'm not a MacPorts expert, but my understanding is that it does *not*
handle that automatically.  If you update your local ports tree and
rebuild, I think it will fail on x11/openmotif because x11/xorg-libXt
was not built as a flat-namespace shared library.  In order to build
x11/xorg-libXt as a flat-namespace shared library, you will need to
enable the flat_namespace variant for x11/xorg-libXt.  That doesn't
happen automatically.
Lewis
Re: OS X edm/medm openmotif woes Wang Xiaoqiang
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes J. Lewis Muir
Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
Prev: RE: ERROR -111 in Keithley6485 Mark Rivers
Next: StreamDevice fails to compile for RTEMS Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
Next: Re: OS X edm/medm openmotif woes Wang Xiaoqiang
ANJ, 17 Nov 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
