Hi Lewis,
After checking, my medm is linked only to MacPorts libraries.
As you said, the key issue is the flat_namespace flag. Luckily Macports handles that automatically if the xorg-libXt is installed as a dependency to openmotif.
Best
Xiaoqiang
> On 16 Nov 2016, at 18:55, J. Lewis Muir <[email protected]> wrote:
> On 11/16, Wang Xiaoqiang (PSI) wrote:
>> Hi Lewis,
>> I just want to report my working setup of MEDM on macOS Sierra, with
>> XQuartz 2.7.11.
> Hi, Xiaoqiang!
> Thank you for your report!
>> I have installed openmotif from MacPorts
>> $ port installed | grep openmotif
>> openmotif @2.3.4_3 (active)
>> The medm (3.1.9) extension is configured like this
>> $ cat configure/os/CONFIG_SITE.darwin-x86.darwin-x86
>> # DarwinPorts OpenMotif
>> X11_LIB=/opt/local/lib
>> X11_INC=/opt/local/include
>> MOTIF_LIB=/opt/local/lib
>> MOTIF_INC=/opt/local/include
>> I just tried a “make clean&&make”. That still works.
> I suspect that still works because your Motif library (libXm) is using
> the X Toolkit Intrinsics library (libXt) from MacPorts, not the one
> from XQuartz. Can you run the following command on your medm binary to
> confirm?
> --- 8< ---
> $ otool -L ./medm
> ./medm:
> /opt/epics-3.14.12.5/lib/darwin-x86/libca.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
> /opt/epics-3.14.12.5/lib/darwin-x86/libCom.3.14.12.dylib (compatibility version 3.14.0, current version 3.14.12)
> /opt/pkg/lib/libXm.4.dylib (compatibility version 5.0.0, current version 5.4.0)
> /opt/X11/lib/libXt.6.dylib (compatibility version 7.0.0, current version 7.0.0)
> /opt/X11/lib/libXmu.6.dylib (compatibility version 9.0.0, current version 9.0.0)
> /opt/X11/lib/libX11.6.dylib (compatibility version 10.0.0, current version 10.0.0)
> /opt/X11/lib/libXext.6.dylib (compatibility version 11.0.0, current version 11.0.0)
> /usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 307.4.0)
> /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1238.0.0)
> --- >8 ---
> As you can see, my medm is linked against /opt/X11/lib/libXt.6.dylib
> which is provided by XQuartz. I suspect yours will not be linked
> against that one but rather against one from MacPorts.
> Looking at the MacPorts Portfile for x11/openmotif, it contains a
> depends_lib entry for port:xorg-libXt which means it depends on the
> x11/xorg-libXt port. It also contains this line:
> require_active_variants xorg-libXt flat_namespace
> I think that means you would have to specify the flat_namespace
> variant for the x11/xorg-libXt port. And if you've specified
> that variant for the x11/xorg-libXt port, then it links with
> the flags "-Wl,-flat_namespace" which is probably how XQuartz's
> /opt/X11/lib/flat_namespace/libXt.6.dylib was built.
> So, I suspect if you did a fresh build of your MacPorts ports and did
> not specify the flat_namespace variant for the x11/xorg-libXt port,
> it would probably fail to build the x11/openmotif port. Then if you
> added the variant, it would probably succeed. But libXt would not be
> built as a two-level-namespace shared library; it would be built as a
> flat-namespace shared library. You can confirm this by looking for the
> TWOLEVEL flag with otool:
> --- 8< ---
> $ otool -hv /opt/X11/lib/libXt.6.dylib
> Mach header
> magic cputype cpusubtype caps filetype ncmds sizeofcmds flags
> MH_MAGIC_64 X86_64 ALL 0x00 DYLIB 19 2024 NOUNDEFS DYLDLINK TWOLEVEL NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
> $ otool -hv /opt/X11/lib/flat_namespace/libXt.6.dylib
> Mach header
> MH_MAGIC_64 X86_64 ALL 0x00 DYLIB 19 2024 DYLDLINK NO_REEXPORTED_DYLIBS APP_EXTENSION_SAFE
> --- >8 ---
> So, the flat-namespace shared library does not have the TWOLEVEL flag,
> whereas the two-level-namespace shared library does. I think your
> MacPorts libXt will not have the TWOLEVEL flag; this means it is a
> flat-namespace shared library. And that should work, but it's similar
> to my other workaround of moving the two-level-namespace libXt from
> XQuartz out of the way and replacing it with XQuartz's flat-namespace
> version.
> Regards,
> Lewis
- Re: OS X edm/medm openmotif woes J. Lewis Muir
- OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes Jiro Fujita
- Re: OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes Wang Xiaoqiang (PSI)
RE: how to unsubscribe michael.abbott
RE: ERROR -111 in Keithley6485 Mark Rivers
<2016>
<2016>
