1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: OS X edm/medm openmotif woes
To: tech-talk <[email protected]>
Date: Thu, 25 Aug 2016 16:35:21 -0700
I recently switched from MacPorts to homebrew.  As a result my system now has a more recent version of OpenMotif — 2.3.4.  This seems to have broken medm and edm.
They build fine, but attempting to run them results in:
eric 570> edm
Error: attempt to add non-widget child "dsm" to parent "edm" which supports only widgets
eric 571> medm
MEDM Version 3.1.9: Loading aliased fonts.................
SIGSEGV
Abort trap: 6
Suggestions from any X11 experts out there?  I’d hate to have to fall back to MacPorts since homebrew has a lot of other packages, octave being one of the more important, that are much more up to date.
I tried installing and building with lesstif (0.95.2) instead, but that just results in:
eric@33 585> edm
Warning: translation table syntax error: Unknown event type :   EnterWindow
Warning: ... found while parsing '<EnterWindow>:            ManagerEnter()'
Warning: String to TranslationTable conversion encountered errors
Warning: XmManager ClassInitialize: XmeTraitSet failed
Warning: translation table syntax error: Unknown event type :   MapNotify
Warning: ... found while parsing '<MapNotify>:              SWNoop()'
Error: Unresolved inheritance operation
eric@33 586> medm
SIGBUS
Abort trap: 6
Eric Norum
[email protected]
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes J. Lewis Muir
Prev: RE: Bio-Logic SP-300 freddie.akeroyd
Next: Re: OS X edm/medm openmotif woes Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: [CSS] Run script attached to an OPI file when a linking container at another OPI opens it Isabella Stevani
ANJ, 26 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
