1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Epics-Digitizer Communication
Date: Tue, 9 Aug 2016 16:02:36 +0300
Sir, I've just integrated all of things into my example. Now, I'm trying to write an additionary code like "USB1608G.cpp" file on your example, since I have to include configuration for "st.cmd" file like "USB1608GConfig". ( I don't know that I should write ).
However, I don't understand that can I use CAEN's sample example which I integrated to my example ?
I mean, I integrated it properly, but in st.cmd file, should I write a code in order to use a command like "USB1608GConfig", which I'm trying to do right now ?
Or in CAEN's sample example, should I integrate a code script ? If it is like so, how should be it ?
I want to use CAEN's commands like "CAEN_DGTZ_OpenDigitizer". Normal way (without EPICS), this command recognizes the linktype (USB or Ethernet).
In addition, I couldn't imagine how I can use the cpp file, which I've just included from CAEN's samples, in st.cmd file by using commands (caget, camonitor etc. .).
I'm in trouble about communication, configuration, functionality and usage of these situations, sir. Again, I'm sorry if I miss something that you mentioned before.
Thanks in advance.. Best Regards..
Hulusi OZ
2016-08-09 15:11 GMT+03:00 Mark Rivers <[email protected]>:
Please send the following:
- Output of "ls -l"  on the src directory.
- Output of "cat Makefile"
- Output of "cat ReadoutTest_Digitizer.c"
- Complete output when you run "make".
My example for Measurement Computing also has header files and a library file from the vendor.
Sent from my iPhone
On Aug 9, 2016, at 3:02 AM, Hulusi Öz <[email protected]<mailto:h[email protected]>> wrote:
Hi sir,
I was dealing with your suggestions for a day. What I have done is :
I included the CAEN Digitizer libraries,which consist of 2 header files and 1 .so file, into the "/exampleApp/src" folder. I also included a sample example which was written by CAEN.
I followed the steps as the example that you mentioned. However, since the CAEN Digitizer libraries consist of header files, I couldn't configurate with Makefile. I included these lines into the Makefile (apart from the asyn,stream configuration)  :
#LIB_SRCS += ReadoutTest_Digitizer.c
#LIB_SRCS += keyb.c
digitizer_SRCS += ReadoutTest_Digitizer.c
I uncommented the LIB_SRCS lines. In fact, in both way (uncommented/commented) , it gives the same error.
The error is related to the CAEN Digitizer Libraries. It says that "undefined reference to "CAEN....." .
It can't read the library.
According to your example, there were sources files, which are configurated into the Makefile. Additionary libraries also have dbd files which are also related to the sources files.
I'm confusing how to integrate these files into the example in order to recognize the commands which are written by the CAEN company, properly. After that, I can write my own code.
Hulusi Oz
2016-08-08 16:16 GMT+03:00 Mark Rivers <[email protected]<mailto:[email protected].edu>>:
You should not use asynSerialPort or asynGpib.
Look at this file in the Github repository I mentioned
measCompApp<https://github.com/epics-modules/measComp/tree/master/measCompApp>/demoSrc<https://github.com/epics-modules/measComp/tree/master/measCompApp/demoSrc>/drv1608G_V1.cpp
It is a complete example of a driver that uses their library to do simple analog output. It is less than 150 lines of code. You need to write something similar using the Caen library. I suggest you also start with something very simple like just reading the module model number or firmware version if they support that. Then you add complexity one step at a time.
Sent from my iPhone
On Aug 8, 2016, at 9:07 AM, Hulusi Öz <[email protected]<mailto:h[email protected]><mailto:hu[email protected]<mailto:hulu[email protected]>>> wrote:
I understand sir, but I'm confused about which module part I should use. I mean, I've used asynSerialPort so far and I'm trying to use asynPortConfigure and asynGPIB module parts, right now.
Is that acceptable for using with asynSerialPort or the other modules ? Or should I configure somethings inside the application ?
I couldn't relate something these configurations, so I'm sorry if I miss something important from your suggestions.
Thanks in advance.Best Regards..
Hulusi Oz
2016-08-08 15:33 GMT+03:00 Mark Rivers <[email protected]<mailto:[email protected].edu><mailto:rivers@cars.uchicago.edu<mailto:rivers@cars.uchicago.edu>>>:
Yes, can include those libraries in your EPICS application. That is exactly what the Measurement Computing examples I mentioned in my previous message do. They use the library from Measurement Computing to communicate with Measurement Computing devices. You will do something very similar, using the Caen libraries to communicate with the Caen device.
Sent from my iPhone
On Aug 8, 2016, at 3:17 AM, Hulusi Öz <[email protected]<mailto:h[email protected]><mailto:hu[email protected]<mailto:hulu[email protected]>><mailto:hulu[email protected]<mailto:hulusi[email protected]><mailto:hulusi.[email protected]<mailto:hulusi.[email protected]>>>> wrote:
Hi sir,
I've been trying to solve it since last week, but I couldn't configure. Therefore, I got the CAEN Digitizer library, which is used to compile via script by normal way . I mean that I can not communicate via EPICS by current modules (or I couldn't do that), is there any way to include those libraries into the EPICS in order to communicate ? Can I integrate it ?
Thanks in advance..Best Regards..
Hulusi Oz
2016-08-01 14:17 GMT+03:00 Mark Rivers <[email protected]<mailto:[email protected].edu><mailto:rivers@cars.uchicago.edu<mailto:rivers@cars.uchicago.edu>><mailto:riv[email protected]<mailto:r[email protected]><mailto:[email protected].edu<mailto:rivers@cars.uchicago.edu>>>>:
> However, in asynPortDriver I don't understand where should I change/edit in "st.cmd" file
The driver you write will define a new command to create your driver.  You will put that new command in your st.cmd file.
For another example driver you can look at the Measurement Computing driver:
It uses a vendor library like you will need to do for the Caen digitizer.  The measCompApp/demoSrc directory contains a series of example drivers, increasing in complexity from version 1 through version 5.  The documentation/ directory contains PDF files of talks I have given explaining these drivers.
From: Hulusi Öz [[email protected]<mailto:h[email protected]><mailto:hu[email protected]<mailto:hulu[email protected]>><mailto:hulu[email protected]<mailto:hulusi[email protected]><mailto:hulusi.[email protected]<mailto:hulusi.[email protected]>>>]
Sent: Monday, August 01, 2016 1:21 AM
To: Mark Rivers; Eric Norum
Cc: tech-talk
Thank you for recommendations sir, I'll try to use asynPortDriver. But, in order to do that, I've to understand how it works.
For example, in Serial way, I edit the "st.cmd" to recognize the port name like  "/dev/ttyACM0" .
However, in asynPortDriver I don't understand where should I change/edit in "st.cmd" file ( I'm using testAsynPortDriver in order to understand how it works).
Thanks in advance,
Regards.
Hulusi Oz
2016-07-29 16:39 GMT+03:00 Mark Rivers <[email protected]<mailto:[email protected].edu><mailto:rivers@cars.uchicago.edu<mailto:rivers@cars.uchicago.edu>><mailto:riv[email protected]<mailto:r[email protected]><mailto:[email protected].edu<mailto:rivers@cars.uchicago.edu>>><redir.aspx?REF=eKZj4MgWawTPUu6ckh_nulJoEdWpv5JJKRCQ-X9OX1kwxevV-7nTCAFtYWlsdG86cml2ZXJzQGNhcnMudWNoaWNhZ28uZWR1>>:
You need to edit asyn/configure/CONFIG_SITE.  It contains these lines:
# If you have libusb-1.0 revision 16 or newer and want the USB TMC support set DRV_USBTMC=YES
#DRV_USBTMC=YES
# You can also define this on a per-architecture basis.
# In this example DRV_USBTMC would be built only for linux-x86_64, and not for other architectures
#ifeq (linux-x86_64, $(T_A))
#  DRV_USBTMC=YES
#endif
So you need to uncomment DRV_USBTMC=YES if you have the required support and want to build it.  Then your application Makefile should include the lines:
# testUSBTMC.dbd will be created and installed
DBD += testUSBTMC.dbd
However, I suspect the CAEN device does not use USBTMC.  Apparently they provide a C-callable library to control the digitizer.  You will need to write an EPICS driver using that library.  I suggest you use the asynPortDriver base class if you decide to do this.
From: [email protected]<mailto:tech-talk-bounces@aps.anl.gov><mailto:tech-talk-[email protected]<mailto:tec[email protected]>><mailto:tech-talk-bounces@aps.anl.gov<mailto:tech-talk-[email protected]><mailto:te[email protected]<mailto:tech-talk-bounces@aps.anl.gov>>><redir.aspx?REF=w84iECr0gHZWG1ezAdLxavrVrZHpxT4j7Wa3Qo1cM3swxevV-7nTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.> [[email protected]<mailto:tech-talk-bounces@aps.anl.gov><mailto:tech-talk-[email protected]<mailto:tec[email protected]>><mailto:tech-talk-bounces@aps.anl.gov<mailto:tech-talk-[email protected]><mailto:te[email protected]<mailto:tech-talk-bounces@aps.anl.gov>>><redir.aspx?REF=w84iECr0gHZWG1ezAdLxavrVrZHpxT4j7Wa3Qo1cM3swxevV-7nTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.>] on behalf of Hulusi Öz [[email protected]<mailto:h[email protected]><mailto:hu[email protected]<mailto:hulu[email protected]>><mailto:hulu[email protected]<mailto:hulusi[email protected]><mailto:hulusi.[email protected]<mailto:hulusi.[email protected]>>><redir.aspx?REF=NCRLsicWEiHm-2mhS-erbYxVUMtVd-9QbQ8pHme9SAswxevV-7nTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.>]
Sent: Friday, July 29, 2016 8:15 AM
To: Ford, Christopher
Cc: Eric Norum; tech-talk
Hi again,
I've just talked with CAEN's supports and there isn't a support module to communicate with that digitizer.
Before I did not get that mail from them, I was dealing with the asynUSBTMC and asynPortDriver.
In USBTMC, I could not handle anything with that. I don't know what the problem is. It keep says that :
# Configure hardware
# usbtmcConfigure(port, vendorNum, productNum, serialNumberStr, priority, flags)
usbtmcConfigure("usbtmc1")
st.cmd line 18: Command usbtmcConfigure not found.
asynSetTraceIOMask("usbtmc1",0,0x2)
st.cmd line 19: Command asynSetTraceIOMask not found.
asynSetTraceMask("usbtmc1",0,0x03)
st.cmd line 20: Command asynSetTraceMask not found.
However, in PortDriver, I am just using test application,but I don't understand how it works, does it support USB port ? If it supports, how can i configurate it (in st.cmd file) ?
I'm searching how to communicate with the digitizer by doing these applications. If there are another suggestions, I would be pleasure to know them..
Thanks in advance..
Best Regards..
Hulusi Oz
2016-07-29 9:54 GMT+03:00 Hulusi Öz <[email protected]<mailto:h[email protected]><mailto:hu[email protected]<mailto:hulu[email protected]>><mailto:hulu[email protected]<mailto:hulusi[email protected]><mailto:hulusi.[email protected]<mailto:hulusi.[email protected]>>><redir.aspx?REF=NCRLsicWEiHm-2mhS-erbYxVUMtVd-9QbQ8pHme9SAswxevV-7nTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.><redir.aspx?REF=T8q0M3CtV41hD9CQXEbnKc8UjqDRZmscyWUU8Tlsi8fI3COVtLfTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.>>:
Unfortunately, I do not have a choice in terms of using optical controller. I am now trying to integrate the usbtmcExample to the my example. But, in somehow it can not recognize the commands like ("usbtmcConfigure(....)"). I included and edited the files in my example in order to recognize USBTMC option of AsynDriver, at this time, when I make the example, it gives an error that says,
/opt/epics/example/exampleApp/src/O.linux-x86_64/example_registerRecordDeviceDriver.cpp:498: undefined reference to `pvar_func_usbtmcRegisterCommands'
collect2: error: ld returned 1 exit status
/opt/epics/base/configure/RULES_BUILD:183: recipe for target 'example' failed
make[3]: *** [example] Error 1
make[3]: Leaving directory '/opt/epics/example/exampleApp/src/O.linux-x86_64'
/opt/epics/base/configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/opt/epics/example/exampleApp/src'
/opt/epics/base/configure/RULES_DIRS:70: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/opt/epics/example/exampleApp'
/opt/epics/base/configure/RULES_DIRS:70: recipe for target 'exampleApp.install' failed
make: *** [exampleApp.install] Error 2
I contacted with the CAEN supports as Eric Norum said that, and I'm waiting for it. Until that time, if there is another suggestions, I will be really glad to know..
Thanks in advance..
Best Regards..
Hulusi
2016-07-29 8:48 GMT+03:00 Ford, Christopher <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:c[email protected]>><mailto:[email protected]<mailto:c[email protected]><mailto:c[email protected]<mailto:ca[email protected]>>><redir.aspx?REF=8q85nb-Es2ZlkFvxf7Ql3ylLBpUL3qtnPnok4MAua1gwxevV-7nTCAFtYWlsdG86Y2FmQHNsYWMuc3RhbmZvcmQuZWR1><redir.aspx?REF=IHzPgOXIEFxvFhJIfWKwqCHTCo0ZUMGK2V0gZNuYYpzI3COVtLfTCAFtYWlsdG86Y2FmQHNsYWMuc3RhbmZvcmQuZWR1>>:
At SLAC we recently evaluated the CAEN DT5730 Digitizer with an eye toward creating EPICS asyn driver support for it.
We used the DT5730's optical interface (by way of the CAEN A3818 optical controller) instead of USB.
CAEN provides C libraries for communicating with their digitizers.  In our experience, these libraries took care of the low-level protocol details.
I haven't tried the digitizer's USB connection.  Check out the CAEN A3818 if you want maximum performance from your DT5730.
 -Chris Ford
  SLAC
From: [email protected]<mailto:tech-talk-bounces@aps.anl.gov><mailto:tech-talk-[email protected]<mailto:tec[email protected]>><mailto:tech-talk-bounces@aps.anl.gov<mailto:tech-talk-[email protected]><mailto:te[email protected]<mailto:tech-talk-bounces@aps.anl.gov>>><redir.aspx?REF=w84iECr0gHZWG1ezAdLxavrVrZHpxT4j7Wa3Qo1cM3swxevV-7nTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.><redir.aspx?REF=7Oie6FFUQRTIz8-tZSaWNgj2EA4TuOs75O4irdhQD8jI3COVtLfTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.> <[email protected]<mailto:tech-talk-bounces@aps.anl.gov><mailto:tech-talk-[email protected]<mailto:tec[email protected]>><mailto:tech-talk-bounces@aps.anl.gov<mailto:tech-talk-[email protected]><mailto:te[email protected]<mailto:tech-talk-bounces@aps.anl.gov>>><redir.aspx?REF=w84iECr0gHZWG1ezAdLxavrVrZHpxT4j7Wa3Qo1cM3swxevV-7nTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.><redir.aspx?REF=7Oie6FFUQRTIz8-tZSaWNgj2EA4TuOs75O4irdhQD8jI3COVtLfTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.>> on behalf of Eric Norum <[email protected]<mailto:eric@norum.ca><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:er[email protected]><mailto:eric@norum.ca<mailto:[email protected]>>><redir.aspx?REF=xn_dJgwadEWp8WsYTkQiNHqNVSonIvXZVD8fUaFHx-8wxevV-7nTCAFtYWlsdG86ZXJpY0Bub3J1bS5jYQ..><redir.aspx?REF=fG7Fkm2HrT0ywGWEp8eihOGpGBih02ithZJ5sGw_uunI3COVtLfTCAFtYWlsdG86ZXJpY0Bub3J1bS5jYQ..>>
Sent: Thursday, July 28, 2016 7:04 AM
To: Hulusi Öz
Cc: tech-talk
The error is indicating that the CAEN device is not a POSIX termios serial port and as such doesn’t accept the ioctl commands to set things like input timeout limits.  I have no idea about the CAEN device protocol.  If it happens to be USBTMC you could use the support for that this is part of ASYN.  Otherwise you’ll have to contact the CAEN folks and see what support they provide for EPICS.
On Jul 27, 2016, at 10:52 PM, Hulusi Öz <[email protected]<mailto:h[email protected]><mailto:hu[email protected]<mailto:hulu[email protected]>><mailto:hulu[email protected]<mailto:hulusi[email protected]><mailto:hulusi.[email protected]<mailto:hulusi.[email protected]>>><redir.aspx?REF=NCRLsicWEiHm-2mhS-erbYxVUMtVd-9QbQ8pHme9SAswxevV-7nTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.><redir.aspx?REF=2df_aqKnfKAog1CVIKQ3xFfhvTymaRSEHPLFtEXpIgUqPiaVtLfTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.>> wrote:
Hi Sir,
I have a few question about communication between Epics and Digitizer (manufactured by CAEN).
I tried to write a basic protocol files that just read analog input,but I don't know that it's true or not. Here it is :
Terminator = LF;
get_analog {
    in " %f";
    ExtraInput = Ignore;
It worked for Arduino. I can get analog values and monitor them on the terminal.
I want to use this in CAEN Digitizer,since I could deal with the Arduino,I suppose..
But,the thing is that when I connect the digitizer to the computer via USB, the IOC output says like that :
2016/07/27 09:28:55.056528 SERIALPORT SERIALPORT:input: asynError in read: Can't set "/dev/v1718_0" c_cc[VTIME]: Inappropriate ioctl for device
2016/07/27 09:28:55.056871 SERIALPORT SERIALPORT:input: I/O error after reading 0 bytes: ""
2016/07/27 09:28:55.056913 SERIALPORT SERIALPORT:input: Protocol aborted
2016/07/27 09:28:55.556477 SERIALPORT SERIALPORT:input: asynError in read: Can't set "/dev/v1718_0" c_cc[VTIME]: Inappropriate ioctl for device
I installed the CAEN driver for this product (Digitizer DT 5730 in <http://www.caen.it/csite/CaenProd.jsp?parent=14&idmod=757<redir.aspx?REF=8S209k7WJkxJ84WNpBsIhFK5oaq3dzXHkKuV2n9NsXYwxevV-7nTCAFodHRwOi8vd3d3LmNhZW4uaXQvY3NpdGUvQ2FlblByb2QuanNwP3BhcmVudD0xNCZpZG1vZD03NTc.><redir.aspx?REF=t1tbwaw0QIs8Fmgup-Wt7VXjvNfNs3U3_O6_k5bXHV4qPiaVtLfTCAFodHRwOi8vd3d3LmNhZW4uaXQvY3NpdGUvQ2FlblByb2QuanNwP3BhcmVudD0xNCZpZG1vZD03NTc.>>) at the path "/lib/modules/4.4.0-31-generic/kernel/drivers" . When I connect it, to learn which port number that it uses , v1718_0
The way I learnt it is that :
ls /dev > notplugged // then I plug the Arduino
ls /dev > plugged
diff notplugged plugged.
Its result for the Arduino says, Serial /ttymACM0,and it works. However the result for the Digitizer says, USB /v1718_0 .
I am using Asyn Driver and StreamDevice.. I don't know that should I use another extensions or support for this product: I search on this website but I couldn't find..
Thanks in advance, sir..
Regards..
Hulusi Oz
Eric Norum
[email protected]<mailto:eric@norum.ca><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:er[email protected]><mailto:eric@norum.ca<mailto:[email protected]>>><redir.aspx?REF=xn_dJgwadEWp8WsYTkQiNHqNVSonIvXZVD8fUaFHx-8wxevV-7nTCAFtYWlsdG86ZXJpY0Bub3J1bS5jYQ..><redir.aspx?REF=CX5KSNTq4DQ0iicWgZQDG2s8SvpI6laHs83odfIk4tgqPiaVtLfTCAFtYWlsdG86ZXJpY0Bub3J1bS5jYQ..>
Re: Epics-Digitizer Communication Eric Norum
Re: Epics-Digitizer Communication Ford, Christopher
Re: Epics-Digitizer Communication Hulusi Öz
RE: Epics-Digitizer Communication Mark Rivers
Re: Epics-Digitizer Communication Mark Rivers
Prev: Re: How to add pv name to data browser in Boy OPI file Kasemir, Kay
Next: Re: Pilatus AD 2-4 errors Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Epics-Digitizer Communication Mark Rivers
Next: NDArrayPool::alloc failing Phil Atkin
ANJ, 09 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
