I have a few question about communication between Epics and Digitizer (manufactured by CAEN).
I tried to write a basic protocol files that just read analog input,but I don't know that it's true or not. Here it is :
Terminator = LF;
get_analog {
in " %f";
ExtraInput = Ignore;
It worked for Arduino. I can get analog values and monitor them on the terminal.
I want to use this in CAEN Digitizer,since I could deal with the Arduino,I suppose..
But,the thing is that when I connect the digitizer to the computer via USB, the IOC output says like that :
2016/07/27 09:28:55.056528 SERIALPORT SERIALPORT:input: asynError in read: Can't set "/dev/v1718_0" c_cc[VTIME]: Inappropriate ioctl for device
2016/07/27 09:28:55.056871 SERIALPORT SERIALPORT:input: I/O error after reading 0 bytes: ""
2016/07/27 09:28:55.056913 SERIALPORT SERIALPORT:input: Protocol aborted
2016/07/27 09:28:55.556477 SERIALPORT SERIALPORT:input: asynError in read: Can't set "/dev/v1718_0" c_cc[VTIME]: Inappropriate ioctl for device
The way I learnt it is that :
ls /dev > notplugged // then I plug the Arduino
ls /dev > plugged
diff notplugged plugged.
Its result for the Arduino says, Serial /ttymACM0,and it works. However the result for the Digitizer says, USB /v1718_0 .
I am using Asyn Driver and StreamDevice.. I don't know that should I use another extensions or support for this product: I search on this website but I couldn't find..
Thanks in advance, sir..
Regards..
