1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Epics-Digitizer Communication
To: Hulusi Öz <[email protected]>, "Ford, Christopher" <[email protected]>
Cc: Eric Norum <[email protected]>, tech-talk <[email protected]>
Date: Fri, 29 Jul 2016 13:39:29 +0000
You need to edit asyn/configure/CONFIG_SITE.  It contains these lines:
# If you have libusb-1.0 revision 16 or newer and want the USB TMC support set DRV_USBTMC=YES
#DRV_USBTMC=YES
# You can also define this on a per-architecture basis.
# In this example DRV_USBTMC would be built only for linux-x86_64, and not for other architectures
#ifeq (linux-x86_64, $(T_A))
#  DRV_USBTMC=YES
#endif
So you need to uncomment DRV_USBTMC=YES if you have the required support and want to build it.  Then your application Makefile should include the lines:
# testUSBTMC.dbd will be created and installed
DBD += testUSBTMC.dbd
However, I suspect the CAEN device does not use USBTMC.  Apparently they provide a C-callable library to control the digitizer.  You will need to write an EPICS driver using that library.  I suggest you use the asynPortDriver base class if you decide to do this.
From: [email protected] [[email protected]] on behalf of Hulusi Öz [[email protected]]
Sent: Friday, July 29, 2016 8:15 AM
To: Ford, Christopher
Cc: Eric Norum; tech-talk
Subject: Re: Epics-Digitizer Communication
Hi again,
I've just talked with CAEN's supports and there isn't a support module to communicate with that digitizer.
Before I did not get that mail from them, I was dealing with the asynUSBTMC and asynPortDriver.
In USBTMC, I could not handle anything with that. I don't know what the problem is. It keep says that :
# Configure hardware
# usbtmcConfigure(port, vendorNum, productNum, serialNumberStr, priority, flags)
usbtmcConfigure("usbtmc1")
st.cmd line 18: Command usbtmcConfigure not found.
asynSetTraceIOMask("usbtmc1",0,0x2)
st.cmd line 19: Command asynSetTraceIOMask not found.
asynSetTraceMask("usbtmc1",0,0x03)
st.cmd line 20: Command asynSetTraceMask not found.
However, in PortDriver, I am just using test application,but I don't understand how it works, does it support USB port ? If it supports, how can i configurate it (in st.cmd file) ?
I'm searching how to communicate with the digitizer by doing these applications. If there are another suggestions, I would be pleasure to know them..
Thanks in advance..
Best Regards..
Hulusi Oz
2016-07-29 9:54 GMT+03:00 Hulusi Öz <[email protected]<redir.aspx?REF=T8q0M3CtV41hD9CQXEbnKc8UjqDRZmscyWUU8Tlsi8fI3COVtLfTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.>>:
Unfortunately, I do not have a choice in terms of using optical controller. I am now trying to integrate the usbtmcExample to the my example. But, in somehow it can not recognize the commands like ("usbtmcConfigure(....)"). I included and edited the files in my example in order to recognize USBTMC option of AsynDriver, at this time, when I make the example, it gives an error that says,
/opt/epics/example/exampleApp/src/O.linux-x86_64/example_registerRecordDeviceDriver.cpp:498: undefined reference to `pvar_func_usbtmcRegisterCommands'
collect2: error: ld returned 1 exit status
/opt/epics/base/configure/RULES_BUILD:183: recipe for target 'example' failed
make[3]: *** [example] Error 1
make[3]: Leaving directory '/opt/epics/example/exampleApp/src/O.linux-x86_64'
/opt/epics/base/configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/opt/epics/example/exampleApp/src'
/opt/epics/base/configure/RULES_DIRS:70: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/opt/epics/example/exampleApp'
/opt/epics/base/configure/RULES_DIRS:70: recipe for target 'exampleApp.install' failed
make: *** [exampleApp.install] Error 2
I contacted with the CAEN supports as Eric Norum said that, and I'm waiting for it. Until that time, if there is another suggestions, I will be really glad to know..
Thanks in advance..
Best Regards..
Hulusi
2016-07-29 8:48 GMT+03:00 Ford, Christopher <[email protected]<redir.aspx?REF=IHzPgOXIEFxvFhJIfWKwqCHTCo0ZUMGK2V0gZNuYYpzI3COVtLfTCAFtYWlsdG86Y2FmQHNsYWMuc3RhbmZvcmQuZWR1>>:
At SLAC we recently evaluated the CAEN DT5730 Digitizer with an eye toward creating EPICS asyn driver support for it.
We used the DT5730's optical interface (by way of the CAEN A3818 optical controller) instead of USB.
CAEN provides C libraries for communicating with their digitizers.  In our experience, these libraries took care of the low-level protocol details.
I haven't tried the digitizer's USB connection.  Check out the CAEN A3818 if you want maximum performance from your DT5730.
 -Chris Ford
  SLAC
From: [email protected]<redir.aspx?REF=7Oie6FFUQRTIz8-tZSaWNgj2EA4TuOs75O4irdhQD8jI3COVtLfTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.> <[email protected]<redir.aspx?REF=7Oie6FFUQRTIz8-tZSaWNgj2EA4TuOs75O4irdhQD8jI3COVtLfTCAFtYWlsdG86dGVjaC10YWxrLWJvdW5jZXNAYXBzLmFubC5nb3Y.>> on behalf of Eric Norum <[email protected]<redir.aspx?REF=fG7Fkm2HrT0ywGWEp8eihOGpGBih02ithZJ5sGw_uunI3COVtLfTCAFtYWlsdG86ZXJpY0Bub3J1bS5jYQ..>>
Sent: Thursday, July 28, 2016 7:04 AM
To: Hulusi Öz
Cc: tech-talk
The error is indicating that the CAEN device is not a POSIX termios serial port and as such doesn’t accept the ioctl commands to set things like input timeout limits.  I have no idea about the CAEN device protocol.  If it happens to be USBTMC you could use the support for that this is part of ASYN.  Otherwise you’ll have to contact the CAEN folks and see what support they provide for EPICS.
On Jul 27, 2016, at 10:52 PM, Hulusi Öz <[email protected]<redir.aspx?REF=2df_aqKnfKAog1CVIKQ3xFfhvTymaRSEHPLFtEXpIgUqPiaVtLfTCAFtYWlsdG86aHVsdXNpLm96MUBnbWFpbC5jb20.>> wrote:
Hi Sir,
I have a few question about communication between Epics and Digitizer (manufactured by CAEN).
I tried to write a basic protocol files that just read analog input,but I don't know that it's true or not. Here it is :
Terminator = LF;
get_analog {
    in " %f";
    ExtraInput = Ignore;
It worked for Arduino. I can get analog values and monitor them on the terminal.
I want to use this in CAEN Digitizer,since I could deal with the Arduino,I suppose..
But,the thing is that when I connect the digitizer to the computer via USB, the IOC output says like that :
2016/07/27 09:28:55.056528 SERIALPORT SERIALPORT:input: asynError in read: Can't set "/dev/v1718_0" c_cc[VTIME]: Inappropriate ioctl for device
2016/07/27 09:28:55.056871 SERIALPORT SERIALPORT:input: I/O error after reading 0 bytes: ""
2016/07/27 09:28:55.056913 SERIALPORT SERIALPORT:input: Protocol aborted
2016/07/27 09:28:55.556477 SERIALPORT SERIALPORT:input: asynError in read: Can't set "/dev/v1718_0" c_cc[VTIME]: Inappropriate ioctl for device
I installed the CAEN driver for this product (Digitizer DT 5730 in <http://www.caen.it/csite/CaenProd.jsp?parent=14&idmod=757<redir.aspx?REF=t1tbwaw0QIs8Fmgup-Wt7VXjvNfNs3U3_O6_k5bXHV4qPiaVtLfTCAFodHRwOi8vd3d3LmNhZW4uaXQvY3NpdGUvQ2FlblByb2QuanNwP3BhcmVudD0xNCZpZG1vZD03NTc.>>) at the path "/lib/modules/4.4.0-31-generic/kernel/drivers" . When I connect it, to learn which port number that it uses , v1718_0
The way I learnt it is that :
ls /dev > notplugged // then I plug the Arduino
ls /dev > plugged
diff notplugged plugged.
Its result for the Arduino says, Serial /ttymACM0,and it works. However the result for the Digitizer says, USB /v1718_0 .
I am using Asyn Driver and StreamDevice.. I don't know that should I use another extensions or support for this product: I search on this website but I couldn't find..
Thanks in advance, sir..
Regards..
Hulusi Oz
Eric Norum
[email protected]<redir.aspx?REF=CX5KSNTq4DQ0iicWgZQDG2s8SvpI6laHs83odfIk4tgqPiaVtLfTCAFtYWlsdG86ZXJpY0Bub3J1bS5jYQ..>
Re: Epics-Digitizer Communication Hulusi Öz
Re: Epics-Digitizer Communication Eric Norum
Re: Epics-Digitizer Communication Ford, Christopher
Prev: Re: Epics-Digitizer Communication Eric Norum
Next: Re: NDArrayPool::alloc failing Phil Atkin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Epics-Digitizer Communication Hulusi Öz
ANJ, 01 Aug 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
