Unfortunately, I do not have a choice in terms of using optical controller. I am now trying to integrate the usbtmcExample to the my example. But, in somehow it can not recognize the commands like ("usbtmcConfigure(....)"). I included and edited the files in my example in order to recognize USBTMC option of AsynDriver, at this time, when I make the example, it gives an error that says, /opt/epics/example/exampleApp/src/O.linux-x86_64/example_registerRecordDeviceDriver.cpp:498: undefined reference to `pvar_func_usbtmcRegisterCommands' collect2: error: ld returned 1 exit status /opt/epics/base/configure/RULES_BUILD:183: recipe for target 'example' failed make[3]: *** [example] Error 1 make[3]: Leaving directory '/opt/epics/example/exampleApp/src/O.linux-x86_64' /opt/epics/base/configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/opt/epics/example/exampleApp/src' /opt/epics/base/configure/RULES_DIRS:70: recipe for target 'src.install' failed make[1]: *** [src.install] Error 2 make[1]: Leaving directory '/opt/epics/example/exampleApp' /opt/epics/base/configure/RULES_DIRS:70: recipe for target 'exampleApp.install' failed make: *** [exampleApp.install] Error 2 I contacted with the CAEN supports as Eric Norum said that, and I'm waiting for it. Until that time, if there is another suggestions, I will be really glad to know.. Thanks in advance.. Best Regards.. Hulusi 2016-07-29 8:48 GMT+03:00 Ford, Christopher <[email protected]>:
ANJ, 29 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
