It is all really the same thing, which is the behavior of asynPortDriver. It only does callbacks to device support when a value changes. This is the desired behavior most of the time. You can currently easily work around that by setting 2 different values before calling callParamCallbacks. I will add a forceCallbacks() method for the next release of asyn.
You need to keep in mind that even if the driver does the callback to device support, the record may not post a new monitor on the value, depending on the record type and the value of the MDEL field.
Sent from my iPhone
> On May 27, 2016, at 2:42 AM, Torsten Bögershausen <[email protected]> wrote:
> To my understanding,
> we are talking about 3 different things:
> a) an asyn record
> b) a motor Record
> c) Area Detector
> I can only talk about b), and there is no update,
> you still need a workaround in the driver, at least for now.
> How the area detector is related to the motor update, I don't know.
> HTH
>> On 27/05/16 04:49, Henrique Almeida wrote:
>> I don't think so, I had this problem on Wednesday while writing an areaDetector
>> IOC that updates a waveform record whenever a new image is saved. If the same
>> file name is used twice in a row, the second callback does not emit a monitor
>> event. I'm using EPICS base 3.16 and asyn and areaDetector github master branch.
>> Em 26/05/2016 10:08, "Mark Davis" <[email protected] <mailto:[email protected]>>
>> escreveu:
>> On 5/26/2016 1:52 AM, Torsten Bögershausen wrote:
>> I remember that Mark Rivers had said something about changing it so that a
>> callback would happen for parameters for which the appropriate
>> setXxxParam() function was called, even if the value had not changed. And
>> I THINK that it made it in to one of the more recent versions, but if so, I
>> don't remember which one.
>> Mark Davis, FRIB/NSCL
>>> To my knowledge,
>>> there is no update.
>>> In our driver, we do it like this:
>>> /* If not moving, trigger a record processing at low rate */
>>> if (!nowMoving) setDoubleParam(pC_->motorPosition_,
>>> newPositionInSteps + 1);
>>> setDoubleParam(pC_->motorPosition_, newPositionInSteps);
>>> And I added a test case:
>>> https://github.com/EuropeanSpallationSource/MCAG_Base_Project/blob/master/epics/test/500_DLY-STOP.py
>>> Out of curiosity:
>>> Which kind of device are you using ?
>>>> On 25/05/16 23:50, Ford, Christopher wrote:
>>>> Hi,
>>>> In 2015 there was some discussion on Tech-Talk about how to force a
>>>> callback for a parameter that had not changed values.
>>>> Mark Rivers suggested a work-around, as shown below.
>>>> I wonder if anyone has an update on the situation since then? Has any
>>>> other method appeared? Or did you have success with the work-around?
>>>> Thanks,
>>>> -Chris Ford, SLAC
>>>> On16 Nov 2015 Mark Rivers writes:
>>>>> If a driver wants to force a callback there is a method that does not
>>>>> require any changes to the base classes, e.g. exposing statusChanged_
>>>>> as protected or adding a new
>>>>> isMotorRecordnowFilterButAlwaysProcess_ flag. The driver simply needs
>>>>> to set a parameter to a different value from present and then back to
>>>>> its current value, for example
>>>>> setDoubleParam(pC_->motorPosition_(position+1.);
>>>>> setDoubleParam(pC_->motorPosition_(position);
>>>>> callParamCallbacks();
>> Mark Davis
>> NSCL/FRIB Control Systems Software Engineer
> a
- Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
- Area Detector question Jörn Wüstenfeld
- RE: Area Detector question ulrik.pedersen
- RE: Area Detector question Mark Rivers
- asyn: what if a driver wants to force callbacks? Ford, Christopher
- Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
- Re: asyn: what if a driver wants to force callbacks? Mark Davis
archiver appliance vs. data browser Schmeißer, Martin
Re: archiver appliance vs. data browser junkes
<2016>
<2016>
