On 5/26/2016 1:52 AM, Torsten
Bögershausen wrote:
I remember that Mark Rivers had said something about changing it so
that a callback would happen for parameters for which the
appropriate setXxxParam() function was called, even if the value had
not changed. And I THINK that it made it in to one of the more
recent versions, but if so, I don't remember which one.
Mark Davis, FRIB/NSCL
To my knowledge,
there is no update.
In our driver, we do it like this:
/* If not moving, trigger a record processing at low rate */
if (!nowMoving) setDoubleParam(pC_->motorPosition_,
newPositionInSteps + 1);
setDoubleParam(pC_->motorPosition_, newPositionInSteps);
And I added a test case:
https://github.com/EuropeanSpallationSource/MCAG_Base_Project/blob/master/epics/test/500_DLY-STOP.py
Out of curiosity:
Which kind of device are you using ?
On 25/05/16 23:50, Ford, Christopher wrote:
In 2015 there was some discussion on Tech-Talk about how to
force a callback for a parameter that had not changed values.
Mark Rivers suggested a work-around, as shown below.
I wonder if anyone has an update on the situation since then?
Has any other method appeared? Or did you have success with the
work-around?
-Chris Ford, SLAC
On16 Nov 2015 Mark Rivers writes:
If a driver wants to force a callback
there is a method that does not require any changes to the
base classes, e.g. exposing statusChanged_ as protected or
adding a new
isMotorRecordnowFilterButAlwaysProcess_ flag. The driver
simply needs to set a parameter to a different value from
present and then back to its current value, for example
setDoubleParam(pC_->motorPosition_(position+1.);
setDoubleParam(pC_->motorPosition_(position);
callParamCallbacks();
Mark Davis
NSCL/FRIB Control Systems Software Engineer
[email protected]
- Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
- Area Detector question Jörn Wüstenfeld
- RE: Area Detector question ulrik.pedersen
- RE: Area Detector question Mark Rivers
- asyn: what if a driver wants to force callbacks? Ford, Christopher
- Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
RE: EPICS meeting : HW platform support discussion group tom.cobb
RE: EPICS meeting : HW platform support discussion group Mooney, Tim M.
<2016>
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
