One item on my to-do list for areaDetector is to add 2 new plugins:
- NDPluginFanOut This plugin would have a list of clients that are registered for callbacks, as all plugins currently do. However, rather than passing each new NDArray to all registered callbacks, it would only send each NDArray to a single registered callback. This would provide a means to have multiple plugins "sharing" the work load, each in its own thread/core.
- NDPluginFanIn This plugin would register for callbacks from multiple data sources (drivers, other plugins) and merge the NDarrays into a single stream. One question is whether it should attempt to do any reordering, i.e. attempt to output the arrays in order of their UniqueID.
NDPluginFanIn could be used for the task you asked about.
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Tuesday, April 26, 2016 2:27 AM
To: [email protected]; [email protected]
Subject: RE: Area Detector question
Hi Jörn,
It is not currently possible to do that. The areaDetector plugins and drivers can produce data to multiple consumers (fan-out) but the plugins can only listen to a single consumer - there is no option to "fan-in".
The HDF5 file writer plugin does have a feature which allows writing NDArrays to multiple datasets with the redirection based on dataset names attached to the individual NDArrays as NDAttributes. So we could possibly make it work if we had a "fan-in" plugin which could listen to multiple sources of data and output a single, merged stream of NDArrays... This would be a rather unique plugin and I'm not entirely sure what complications may crop up...
A much simpler alternative is to write a file per camera and have a top-level file which ties everything together using HDF5 "external links". If multiple datasets should appear as a single dataset then the new HDF5 1.10.0 Virtual Dataset feature could be used to give a single dataset view.
https://www.hdfgroup.org/HDF5/doc/RM/RM_H5L.html
https://www.hdfgroup.org/HDF5/docNewFeatures/NewFeaturesVirtualDatasetDocs.html
Cheers,
Ulrik
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jörn Wüstenfeld
Sent: 26 April 2016 07:30
To: tech-talk tech-talk
Subject: Area Detector question
Hello,
after I have succesfully read a single Basler camera and stored the data in an
HDF5 file, I now want to read out more cameras on the same IOC and store the data together in one file. Is that Possible?
Or can one setup another IOC that collects the data from several IOC's and stores them in one file?
Regards
Jörn
- asyn: what if a driver wants to force callbacks? Ford, Christopher
- Area Detector question Jörn Wüstenfeld
- RE: Area Detector question ulrik.pedersen
Re: EPICS_TIMEZONE and TZ on RTEMS Michael Davidsaver
Re: EPICS 3.14.12.3 Build Problems with the new Ubuntu 16.04 LTS Michael Davidsaver
<2016>
<2016>
