g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Re: Alter Perl hashbang in capr.pl
To: tech-talk@aps.anl.gov
Date: Fri, 18 Jan 2013 17:19:18 -0600
On 2013-01-18 Ralph Lange wrote:
> A more elegant portable solution is replacing the hashbang with
>     eval 'exec perl -S $0 ${1+"$@"}' # -*- Mode: perl -*-
>         if 0;
> That will find perl in the PATH.
It seems the recommended way to handle this has changed a bit over the years.
The current trend for both Perl and Python seems to be to use /usr/bin/env,
which finds perl in the path without being quite so verbose:
#!/usr/bin/env perl
All modern Unix-type systems understand the #! line and have the env program
in /usr/bin — even Solaris and Cygwin.  The magical parts in the above eval
were needed to get around various specific shells that might be executing the
script, but I don't believe anyone will be trying to run EPICS on the exotic
ones nowadays (and they're not needed if the script has a #! line).
Windows does not understand either the #! line or any of the above magic, so
the EPICS build system always explicitly includes $(PERL) in the command line
and I think manually running perl scripts will always require that too.
I propose to change the preamble of all the Perl scripts in base-3.14 to the
above; any objections?  There's a patch file of the necessary changes at
  http://www.aps.anl.gov/epics/base/R3-14/12-docs/envPerl.patch
- Andrew
There is no such thing as a free lunch.  When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Re: Alter Perl hashbang in capr.pl J. Lewis Muir
Alter Perl hashbang in capr.pl Shankar, Murali
Re: Alter Perl hashbang in capr.pl Ralph Lange
Prev: Re: Alter Perl hashbang in capr.pl J. Lewis Muir
Next: femto and std Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Next: Re: Alter Perl hashbang in capr.pl J. Lewis Muir
ANJ, 22 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
