g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
Subject: Alter Perl hashbang in capr.pl
From: "Shankar, Murali" <mshankar@slac.stanford.edu>
To: "'tech-talk@aps.anl.gov'" <tech-talk@aps.anl.gov>
Date: Fri, 18 Jan 2013 10:45:37 -0800
Hello,
I have a EPICS build facility question.
In our various environments, in addition to the default Linux perl in /usr/bin/perl, we have a customized perl (with extra modules) in /usr/local/bin/perl. This customized version is ahead of /usr/bin/perl in the PATH as that’s what we want all our Perl scripts to use.
In addition, I have added a PERL line in configure/CONFIG_SITE like so
PERL=/usr/local/bin/perl
to force use of /usr/local/bin/perl and I have confirmed that this is the Perl that’s being used. And EPICS build fine.
However, the capr.pl (and other perl scripts) still contain hardcoded references to /usr/bin/perl.
head ./bin/linux-x86_64-debug/capr.pl
#!/usr/bin/perl -w
#    capr: A program that attempts to do a "dbpr" command via channel
This causes symbol lookup errors when running capr.pl as the libCap5.so was built using /usr/local/bin/perl but is executing using /usr/bin/perl.
Am I missing some additional configuration here? Any help is appreciated.
Murali
Re: Alter Perl hashbang in capr.pl Ralph Lange
Prev: RE: building epics on windows with visual studio 2012 Hill, Jeff
Next: Re: Alter Perl hashbang in capr.pl Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013
ANJ, 18 Jan 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
