On 1/18/13 2:58 PM, Ralph Lange wrote:
> Hi Murali,
> one way to get around this (this is what the EPICS build system does)
> would be not to use the hashbang by explicitly calling perl with the
> script as argument:
> perl ./bin/linux-x86_64-debug/capr.pl
> Admittedly, this avoids the issue and does not fix it.
> A more elegant portable solution is replacing the hashbang with
> eval 'exec perl -S $0 ${1+"$@"}' # -*- Mode: perl -*-
> if 0;
> That will find perl in the PATH.
?? I would say the correct thing to do would be for the hashbang in
capr.pl (and all others) to be set correctly based on the PERL variable
from the EPICS build system at build time.
Lewis
- Alter Perl hashbang in capr.pl Shankar, Murali
- Re: Alter Perl hashbang in capr.pl Ralph Lange
Re: Alter Perl hashbang in capr.pl Andrew Johnson
<2013>
<2013>
