Trevor,
Do you see waveforms on the scope? if so, select the "ACQUIRE"
page and click on "Stop/Rd/Run" button a couple of times or change
scan from "Passive" to "2 seconds".
Nick D.
On 12/7/2012 7:35 PM, Trevor Downer wrote:
Hello again!
We were able to get the cartesian plot function to work.
I attached a screenshot of the display after our success.
Thanks for your help with that!
The problem was with the MEDM installation, so I re-installed MEDM.
We were able to make a cartesian plot correctly using another application.
However, we still are not getting the trace data from the oscilloscope.
I attached screenshot is of the result that I get when I run the caget
command on one of the wave form records.
This is the same result that I get for the other waveform records as well.
We tried changing the EPICS_CA_MAX_ARRAY_BYTES variable in the
environment, the envParams, and the st.cmd script from 10000 to
100000000, but to no avail as we are still not able to get a trace.
We also tried changing the NELM field in the waveform records from
10000 to 100000 and bigger, and we had the same result.
Any help that you can give us would be greatly appreciated!
Thanks
On Fri, Dec 7, 2012 at 12:10 PM, Hartman, Steven M. <[email protected]> wrote:
On Dec 6, 2012, at 11:51 PM, Yujong Kim wrote:
We can control all main functions of the scope from EPICS MEDM OPI panels without any problem.
Hi Yujong--
To isolate whether this is an medm configuration issue or a CA configuration issue (e.g., EPICS_CA_MAX_ARRAY_BYTES), try to caget the waveform from the computer running medm.
Steven Hartman
[email protected]
- Tektronix 3014 Tracing Problem Trevor Downer
- Re: Tektronix 3014 Tracing Problem Eric Norum
- Re: Tektronix 3014 Tracing Problem Pavel Maslov
- Re: Tektronix 3014 Tracing Problem Yujong Kim
- Re: Tektronix 3014 Tracing Problem Hartman, Steven M.
- Re: Tektronix 3014 Tracing Problem Trevor Downer
Re: Utilities for EPICS on Multi-Core Linux Ralph Lange
James Rowland mark.heron
<2012>
Re: Tektronix 3014 Tracing Problem Nicholas P. DiMonte
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
