Greetings and salutations! I am a student at Idaho State University working on a project to control a Tektronix 3014 oscilloscope, using EPICS, for the Idaho Accelerator Center. We have successfully installed EPICS and the necessary extensions to communicate with the TDS3014 oscilloscope. Using medm we cannot see the waveform tracings, we can however see the tracings from a web browser, however its refresh rate is quite slow. There seems to be a problem when I click on the SDDS Plot button, medm outputs a message in the terminal reading: "medm/trace10k: line 8: [: T: integer expression expected Usage: trace [1-4][HV or LL]<CR>\n" Attached is a screen shot of the traceless oscilloscope in medm and the trace10k file where there seems to be a problem. I would greatly appreciate any help to fixing the tracing problem, thank you very much! -Trevor Downer Attachment:
Tds3000 without a trace.png Attachment:
Trace Issue.png Attachment:
| ANJ, 07 Dec 2012 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
