1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: aiRecord conversion
To: Bruno Seiva Martins <[email protected]>
Date: Tue, 28 Aug 2012 17:31:53 +0200
Hi Bruno,
Your device support should have a function specialLinconv() or similar, which is function number 6 in the device support structure:
struct {
    long      number;
    DEVSUPFUN report;
    DEVSUPFUN init;
    DEVSUPFUN init_record;
    DEVSUPFUN get_ioint_info;
    DEVSUPFUN read;
    DEVSUPFUN special_linconv;
} myAi =
    6,
    NULL,
    NULL,
    initRecordAi,
    getInIntInfoAi,
    readAi,
    specialLinconv
That function may look like this:
STATIC long specialLinconv(aiRecord *record, int after)
    epicsUInt32 hwSpan;
    myPrivate_t *priv = (myPrivate_t *)record->dpvt;
    if (after) {
        hwSpan = (priv->type == LCN12BMP || priv->type == LCN12BBP) ?
		4095 : 65535;
        record->eslo = (record->eguf - record->egul) / hwSpan;
        record->eoff = record->egul;
    return 0;
Call specialLinconv() from initRecordAi(). Additionally, the record will call it automatically when anyone changes EGUL or EGUF.
In initRecordAi(), malloc a private data structure (I called it myPrivate_t) with a field "type" (and anything else you need to store and use later, for example in readAi). Set type and then store the pointer to the structure in record->dpvt before calling specialLinconv().
In the record database, set EGUF to the user value that corresponds to the maximum ADC value (4095 or 65535 depending on your ADC type) and EGUL to the value that corresponds to the minimum ACC value (0). For example 10 and -10 (Volts). You may change that later on the fly and specialLinconv will adjust ESLO and EOFF.
Dirk
Bruno Seiva Martins wrote:
Hi Ralph,
Thanks for your advice! I'm still learning EPICS, so I'm using those A/D's just for experimenting. When it comes to the real deal, I'll keep in mind what you said.
Best regards,
Bruno Seiva Martins
On Tue, Aug 28, 2012 at 11:05 AM, Ralph Lange <[email protected] <mailto:[email protected]>> wrote:
    On Tue Aug 28 2012 15:28:34 GMT+0200 (CEST), Bruno Seiva Martins
    <[email protected]> <mailto:[email protected]> wrote:
    Rectifying:
       epicsFloat64 div;
       pao->eguf = 10.0;
       pao->egul = (type == LCN12BMP || type == LCN16BMP) ? 0.0 : -10.0;
       div = (type == LCN12BMP || type == LCN12BBP) ? 4095.0 : 65535.0;
pao->hopr = pao->eguf; pao->lopr = pao->egul; pao->eslo = ((pao->eguf) - (pao->egul)) / div;
    Bruno Seiva Martins
    Another comment:
    The linear conversion mechanism is intended to convert the digitized
    value into the final engineering units.
    You might want to use your A/D converter for signals that correspond
    to positions [mm], pressures [mbar], or temperatures [C].
    In those cases, the database designer will set EGU, EGUL and EGUF to
    e.g. "mm", -5 and 25, meaning that -10V are equivalent to -5mm, and
    +10V are equivalent to +25mm. To limit the range that is shown in
    the GUI, the designer might also want to set e.g. LOPR to -2 and
    HOPR to +2, so that graphs and meters show the "interesting" range,
    -2mm to +2mm.
    To have this work correctly, setting EGUF, EGUL, HOPR and LOPR in
    your device support may actually not be a good idea.
    Normally, I would just set ESLO and EOFF.
    Cheers,
    ~Ralph
Re: aiRecord conversion Eric Norum
aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Dirk Zimoch
Re: aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Ralph Lange
Prev: Re: aiRecord conversion Eric Norum
Next: Re: aiRecord conversion Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: aiRecord conversion Bruno Seiva Martins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
