Hi all, I am having trouble trying to adjust the conversion parameters of an analog input record for a A/D converter. My AD accepts voltages ranging from -10 to 10 volts and has a resolution of 12 bits.
For -10 volts, it produces a digital output of 0 For 10 volts, 4095 I configured the conversion fields as follows: EGUF: 10
EGUL: -10 AOFF: 0 ASLO: 1 EOFF: 0 ESLO 0.004884 // which is (EGUF - EGUL) / 4095
ROFF: 0 LINR: LINEAR Those values seem right to me but, for example, RVAL=1005 gets converted to VAL=4.9084, when it should be VAL=-5.0916. The problem seems to be that the conversion formula isn't taking into account the EGUL field.
According to the EPICS record reference for aiRecord:
The record processing routine performs the following algorithm for all records except those that use the Seems like the step 3 is not being completely executed, or considering EGUL = 0... Does anybody know what is wrong? Probably I'm missing something really obvious, but I couldn't figure it out...
Thanks in advance, Bruno Seiva Martins
| ANJ, 27 Nov 2012 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
