1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: aiRecord conversion
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 28 Aug 2012 10:26:55 -0300
Hi Dirk,
I wrote a custom Device Support for this record, so DTYP is set to my custom device. Indeed, it is the device support code that sets those parameters, but only in the init_record routine:
   epicsFloat64 div;
   pao->eguf = 10.0;
   pao->egul = (type == LCN12BMP || type == LCN16BMP) ? 0.0 : -10.0;
   div = (type == LCN12BMP || type == LCN12BBP) ? 4095.0 : 65535.0;
   pao->hopr = *eguf;
   pao->lopr = *egul;
   pao->eslo = ((pao->eguf) - (pao->egul)) / div;
After the initialization, those parameters are not changed. The read_ai routine only reads into the RVAL field.
   struct loconState *priv = pao->dpvt;
   epicsUInt16 value = 0;
   LOCON_read_analog(priv->address, priv->type, &value);
   pao->rval = (epicsInt32) value;
   return 0;
Bruno Seiva Martins
On Tue, Aug 28, 2012 at 10:12 AM, Dirk Zimoch <[email protected]> wrote:
Hi Bruno,
Many drivers overwrite EOFF and ESLO with their own calculations (from EGUL and EGUF and their own assumptions about the raw value range).
So the important missing information is: What driver are you using (DTYP)?
Dirk
Bruno Seiva Martins wrote:
Hi all,
I am having trouble trying to adjust the conversion parameters of an analog input record for a A/D converter.
My AD accepts voltages ranging from -10 to 10 volts and has a resolution of 12 bits.
For -10 volts, it produces a digital output of 0
For 10 volts, 4095
I configured the conversion fields as follows:
EGUF: 10
EGUL: -10
AOFF: 0
ASLO: 1
EOFF: 0
ESLO 0.004884   // which is (EGUF - EGUL) / 4095
ROFF: 0
LINR: LINEAR
Those values seem right to me but, for example, RVAL=1005 gets converted to VAL=4.9084, when it should be VAL=-5.0916. The problem seems to be that the conversion formula isn't taking into account the EGUL field.
According to the EPICS record reference for aiRecord:
    The record processing routine performs the following algorithm for
    all records except those that use the |Soft Channel| device support
    routine. Be aware that step 3 is performed only when the record
    specifies LINEAR:
    1. Val= RVAL + ROFF
    2. Val = Val * ASLO + AOFF
    If the conversion algorithm is |LINEAR|, the raw value is converted
    via the equation:
    3. val = val * ESLO + EGUL
Seems like the step 3 is not being completely executed, or considering EGUL = 0...
Does anybody know what is wrong? Probably I'm missing something really obvious, but I couldn't figure it out...
Thanks in advance,
Bruno Seiva Martins
Re: aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Dirk Zimoch
Prev: Re: aiRecord conversion Dirk Zimoch
Next: Re: aiRecord conversion Bruno Seiva Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
