g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: aiRecord conversion
To: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Tue, 28 Aug 2012 16:05:46 +0200
On Tue Aug 28 2012 15:28:34 GMT+0200 (CEST), Bruno Seiva Martins <brunoseivam@gmail.com> wrote:
Rectifying:
   epicsFloat64 div;
   pao->eguf = 10.0;
   pao->egul = (type == LCN12BMP || type == LCN16BMP) ? 0.0 : -10.0;
   div = (type == LCN12BMP || type == LCN12BBP) ? 4095.0 : 65535.0;
   pao->hopr = pao->eguf;
   pao->lopr = pao->egul;
   pao->eslo = ((pao->eguf) - (pao->egul)) / div;
Bruno Seiva Martins
Another comment:
The linear conversion mechanism is intended to convert the digitized value into the final engineering units.
You might want to use your A/D converter for signals that correspond to positions [mm], pressures [mbar], or temperatures [C].
In those cases, the database designer will set EGU, EGUL and EGUF to e.g. "mm", -5 and 25, meaning that -10V are equivalent to -5mm, and +10V are equivalent to +25mm. To limit the range that is shown in the GUI, the designer might also want to set e.g. LOPR to -2 and HOPR to +2, so that graphs and meters show the "interesting" range, -2mm to +2mm.
To have this work correctly, setting EGUF, EGUL, HOPR and LOPR in your device support may actually not be a good idea.
Normally, I would just set ESLO and EOFF.
Cheers,
~Ralph
Re: aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Dirk Zimoch
Prev: Re: aiRecord conversion Bruno Seiva Martins
Next: Re: aiRecord conversion Nicholas P. DiMonte
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: aiRecord conversion Ralph Lange
Next: Re: aiRecord conversion Bruno Seiva Martins
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
