g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Problems in using VX2 motor controller
To: "tech-talk" <tech-talk@aps.anl.gov>
Date: Fri, 30 Mar 2012 09:43:23 +0800
Dear all,
I have downloaded the motor controller software Ver. R4-8 to do some EPICS training.
Two Vx2-002 motor controller mounted in the VME chest, and I modified the "NoMPF.substitutions" file  as follows:
    file basic_motor.db
    pattern
    {P,     N,  M,      DTYP,         C,  S,  DESC,          EGU,      DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
    {rls:,  1,  m$(N),  "OMS VME58",  0,  0,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    {rls:,  2,  m$(N),  "OMS VME58",  0,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    {rls:,  3,  m$(N),  "OMS VME58",  1,  0,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
    {rls:,  4,  m$(N),  "OMS VME58",  1,  1,  "motor $(N)",  degrees,  Pos,  1,     .1,    .2,    0,     1,     .2,    0.01,  5,     100,   -100,  ""}
then, modified the "st.cmd" file as follows:
    # OMS VME driver setup parameters:
    #     (1)cards, (2)axes per card, (3)base address(short, 16-byte boundary),
    #     (4)interrupt vector (0=disable or  64 - 255), (5)interrupt level (1 - 6),
    #     (6)motor task polling rate (min=1Hz,max=60Hz)
    omsSetup(2, 2, 0xFC00, 180, 5, 10)
after gmake, when download the "st.cmd" file, there come some errors:
    filename="../recGbl.c" line number=80
    Illegal field value PV: rls:m3  motor_init_record_com(): card does not exist!
    Illegal field value PV: rls:m4  motor_init_record_com(): card does not exist!
I don't know where the problem is, would you please give me some help, thanks a lot!
2012-03-30
孙纪磊 敬启
中国科学院高能物理研究所1号厅201室
北京市918信箱 100049
Sun Jilei
Institute of High Energy Physics, Chinese Academy of Sciences,
Accelerator Center, Room 201, Hall 1,
19B Yuquan Lu, Shijingshan District,
Beijing 100049,
People's Republic of China
Tel.: (+86)-(0)10-88236287
Email:
sunjl@ihep.ac.cn
RE: Problems in using VX2 motor controller Mark Rivers
Re: Problems in using VX2 motor controller 闫芬
Re: Problems in using VX2 motor controller Ron Sluiter
Re: Re: Problems in using VX2 motor controller sunjl
Prev: Fiber Optic Switches Bjorklund, Eric A
Next: RE: Problems in using VX2 motor controller Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: Fiber Optic Switches Bryce Karnaghan
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
