Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Subject: RE: Fiber Optic Switches
From: Bryce Karnaghan <Bryce.Karnaghan@synchrotron.org.au>
To: EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Mon, 2 Apr 2012 08:35:55 +1000
Eric
Not sure if you are referring to a fibre equipped Ethernet switch or being able to switch a switch a single fibre source to multiple ports. If it is the latter here is a link
http://www.agiltron.com/Fiberoptic%20path%20switch.htm
We were considering using something like this to inhibit the trigger to the e-gun for top up inhibit.
Cheers
Bryce  K
-----Original Message-----
From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of Bjorklund, Eric A
Sent: Friday, 30 March 2012 10:31
To: EPICS tech-talk
Subject: Fiber Optic Switches
We are exploring the use of computer controlled fiber optic switches for switching between redundant signal sources.  Does anybody already use these things?  What brands do you recommend?  How fast do they switch?
All advice gratefully accepted.
Thanks
-Eric Bj.
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Fiber Optic Switches Bjorklund, Eric A
Prev: StripTool and History Paul E. Reimer
Next: casStrmClient.cc error: invalid channel identifier Emma Shepherd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Prev: Re: Fiber Optic Switches Emmanuel Mayssat
Next: Problems in using VX2 motor controller sunjl
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
