1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Make target_arch only ... doesn't seem to work on 3.14.11
To: Janet Anderson <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 21 Feb 2011 09:32:36 -0800
On 09:39 Mon 21 Feb     , Janet Anderson wrote:
> The following lines will force a Makefile to build the abcd LIBRARY only
> for the linux-armv4tl arch.
> LIBRARY_linux-armv4tl = abcd
> LIBRARY = $(LIBRARY_$(T_A))
Very elegant and best of all it works!
Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Re: Make target_arch only ... doesn't seem to work on 3.14.11 Janet Anderson
Prev: RE: TFTP I/O Error Jim Eastman
Next: Re: [Fwd: Re: stream without asynPort] Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Make target_arch only ... doesn't seem to work on 3.14.11 Janet Anderson
Next: TFTP I/O Error Jim Eastman
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
