Subject: |
Re: Make target_arch only ... doesn't seem to work on 3.14.11 |
[email protected] |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 18 Feb 2011 15:53:56 -0800 |
After investigation, I found that it works because I added:
ifeq (${T_A}, linux-x86_64)
exit:
endif
at the top of my Makefile...
Q: Is there a way to force the makefile to build only for one target arch (T_A)?
i.e I want 'make linux-armv4tl' to be the default
Q: Again is there a way to build only one T_A without using the above trick?
E
On 15:30 Fri 18 Feb , [email protected] wrote:
> For some reason, it works now...
> make linux-armv4tl
> Note that make needs to be gnumake
> On 15:12 Fri 18 Feb , [email protected] wrote:
> > I have a 64bit machine which is used to compile arm binaries.
> > make linux-armv4tl
> > according to the manual should build only for the arm system.
> > But obviously it doesn't. First the compilation starts with the host architecture
> > (linux-x86_64 in my case)
> > Q: Is there a way to compile only for a specific T_A ?
Emmanuel
- Re: Make target_arch only ... doesn't seem to work on 3.14.11 Janet Anderson
- Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
- Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
TFTP I/O Error Jim Eastman
<2011>
<2011>
