Subject: |
Re: Make target_arch only ... doesn't seem to work on 3.14.11 |
Janet Anderson <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Mon, 21 Feb 2011 09:39:41 -0600 |
The following lines will force a Makefile to build the abcd LIBRARY
only for the linux-armv4tl arch.
LIBRARY_linux-armv4tl = abcd
LIBRARY = $(LIBRARY_$(T_A))
[email protected] wrote:
After investigation, I found that it works because I added:
ifeq (${T_A}, linux-x86_64)
exit:
endif
at the top of my Makefile...
Q: Is there a way to force the makefile to build only for one target arch (T_A)?
i.e I want 'make linux-armv4tl' to be the default
Q: Again is there a way to build only one T_A without using the above trick?
E
On 15:30 Fri 18 Feb , [email protected] wrote:
For some reason, it works now...
make linux-armv4tl
Note that make needs to be gnumake
On 15:12 Fri 18 Feb , [email protected] wrote:
I have a 64bit machine which is used to compile arm binaries.
make linux-armv4tl
according to the manual should build only for the arm system.
But obviously it doesn't. First the compilation starts with the host architecture
(linux-x86_64 in my case)
Q: Is there a way to compile only for a specific T_A ?
- Re: Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
- Make target_arch only ... doesn't seem to work on 3.14.11 emmanuel_mayssat
Re: stream without asynPort Dirk Zimoch
RE: TFTP I/O Error Jim Eastman
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
